Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 05-18-2017, 08:43   #1 (permalink)
hardboy's Avatar
Member: 863309
Sonork: 4540726
Thanks Meter: 41
Arrow iPad 4 iTunes Error 9
Hello.
iPad in DFU mode.
I already cheange:
USB cable
USB port
Battery
Touch screeen
Erase NAND IP BOX v2
Camera
And still after few second on screen I have info about error 9.
Someone have a solution or good advice how to repair ?
Old 06-24-2017, 12:56   #2 (permalink)
Member: 2588255
Thanks Meter: 29
Hi, try with 3eTools, -> see iTunes. ipad recovery mode when you throw software, does serial no? -> Nand is not ready for the software. No problem reading. Voltage, write feet should be checked..
Old 06-24-2017, 20:12   #3 (permalink)
Crazy Poster
Member: 2697189
Thanks Meter: 37
error 9 is usually unexpected drop from usb, is the battery charged enough minimum 20%?
to rule that out isolate the battery and run at 4.2v 2.1amps via psu, make sure battery posts are isolated. I am fairly sure HDFU which is what you have now is not able to charge a battery, this is due to system priorities in hdfu mode, it runs the barebones systems from usb power.
No serial number can be derived from a fresh nand install in itunes, thats actually why it trips hdfu.
The Following User Says Thank You to TBC01 For This Useful Post:
Page generated in 0.12128 seconds with 8 queries
