Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-23-2017, 11:31   #1 (permalink)
Member: 2332263
Thanks Meter: 12
ipad mini dead no respond
i have an ipad mini which is dead and can even connect to itunes because it doesnt detect on pc ?
what solution can you suggest me ??
is it the board or some other problem??
Old 06-25-2017, 14:36   #2 (permalink)
Member: 2588255
Thanks Meter: 29
hi, check mobo reset resistor "10k" or usb flex cable or lighting cable or other pc.
Old 06-28-2017, 07:03   #3 (permalink)
Member: 2332263
Thanks Meter: 12
where it is situated on the board???
Old 06-30-2017, 07:28   #4 (permalink)
Member: 2588255
Thanks Meter: 29
ok. soon schematic share.
Old 07-05-2017, 15:38   #5 (permalink)
Member: 2732748
does u2 involve in the problem?
Old 07-06-2017, 08:11   #6 (permalink)
Member: 2732748
i have the same problem, ipad mini history before it died is that i used replacement charger, after playing games i put the device on sleep then after 4-6 hrs it was not responding..i tried changing the battery still no luck.. i also tried connecting device in computer without the battery but no response..just need help how to test charging port if it was the reason before coming out a conclusion of faulty u2 ic..ty
Old 09-26-2017, 15:48   #7 (permalink)
Member: 1817612
Thanks Meter: 13
Can you solder with microscope? If yes look at USB charge controller 1608 I believe and check to confirm 5v is present when connected to pc. If no connect response from OC OR MAC, check all components around lightning connector. Use know good charge/sync cable!
Page generated in 0.13313 seconds with 9 queries
