06-23-2017, 11:31 | #1 (permalink) |
Freak Poster Join Date: Jan 2015 Age: 27
Member: 2332263 Status: Offline Thanks Meter: 12 | ipad mini dead no respond what solution can you suggest me ?? is it the board or some other problem?? |
07-06-2017, 08:11 | #6 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2732748 Status: Offline Thanks Meter: 0 | i have the same problem, ipad mini history before it died is that i used replacement charger, after playing games i put the device on sleep then after 4-6 hrs it was not responding..i tried changing the battery still no luck.. i also tried connecting device in computer without the battery but no response..just need help how to test charging port if it was the reason before coming out a conclusion of faulty u2 ic..ty |
09-26-2017, 15:48 | #7 (permalink) |
Freak Poster Join Date: Sep 2012 Location: So. Cal.
Member: 1817612 Status: Offline Thanks Meter: 13 | Can you solder with microscope? If yes look at USB charge controller 1608 I believe and check to confirm 5v is present when connected to pc. If no connect response from OC OR MAC, check all components around lightning connector. Use know good charge/sync cable! |
