iPad , iPod , Apple TV iPad 1 , iPad 2 , iPad 3 , iPad Mini , iPad 4 / iPod Classic , iPod Nano , iPod Touch / Apple TV |
02-12-2019, 20:30 | #1 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2418671 Status: Offline Thanks Meter: 7 | iPad Pro 9.7 Stuck in DFU mode |
The Following User Says Thank You to stlshocker For This Useful Post: |
09-29-2019, 10:25 | #4 (permalink) |
Insane Poster Join Date: Jan 2018
Member: 2797527 Status: Offline Thanks Meter: 4 | As I know, error 9 is a hardware-related issue on iOS devices. Maybe you should take your iPad to Apple store to repair. However, before that, you can try to fix iPad stuck in DFU mode by using solutions, like hard reset, restore with iTunes or repair with a professional tool, Joyoshare UltFix. Here is what I know about the iPhone gets stuck in DFU mode, which is also applicable to your iPad Pro: How to Fix iPhone Stuck in DFU Mode |
10-07-2019, 19:28 | #5 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1675922 Status: Offline Thanks Meter: 61 | If board is able to switch from dfu to recovery without nand soldered, it means that cpu and ram are ok. Very important: for switch to recovery the board must be powered from battery or power supply. Otherwise, hard to say what is the cause and usually not fixable. |
12-18-2020, 06:58 | #6 (permalink) |
Crazy Poster Join Date: Jul 2020 Location: China Age: 25
Member: 2964041 Status: Offline Thanks Meter: 3 | The error 9 happened on your iPad could result from hardware or software issues, which can usually be solved by hard resetting your iPad, use professional ios repair tools like TunesKit iOS System Recovery and restoring iPad via iTunes. Please read Fixed: iPad Stuck in DFU Mode to help you get rid of it. |
12-18-2020, 06:58 | #7 (permalink) |
