Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPad , iPod , Apple TV
iPad , iPod , Apple TV iPad 1 , iPad 2 , iPad 3 , iPad Mini , iPad 4 / iPod Classic , iPod Nano , iPod Touch / Apple TV
Old 02-12-2019, 20:30   #1 (permalink)
Member: 2418671
Thanks Meter: 7
iPad Pro 9.7 Stuck in DFU mode
I have some iPad pros that have error 9. I have carefully taken off NAND, formatted, rewrote syscfg data, wrote original information back on to NAND and then carefully put it back on device and now I have 3 that when connected with iTunes say waiting for iPad forever, if connected to 3utools it is unable to switch from DFU mode to Recovery. I have made sure to carefully cover up CPU and RAM to insure I do not overheat them. What else could be causing the issue?
The Following User Says Thank You to stlshocker For This Useful Post:
Old 07-17-2019, 00:39   #2 (permalink)
Member: 2192826
rewrite the data on nand
Old 09-26-2019, 13:34   #3 (permalink)
Member: 125424
Thanks Meter: 21
I have same iPad problem that have error 9.
Old 09-29-2019, 10:25   #4 (permalink)
Member: 2797527
Thanks Meter: 4
As I know, error 9 is a hardware-related issue on iOS devices. Maybe you should take your iPad to Apple store to repair. However, before that, you can try to fix iPad stuck in DFU mode by using solutions, like hard reset, restore with iTunes or repair with a professional tool, Joyoshare UltFix.
Here is what I know about the iPhone gets stuck in DFU mode, which is also applicable to your iPad Pro: How to Fix iPhone Stuck in DFU Mode
Old 10-07-2019, 19:28   #5 (permalink)
Member: 1675922
Thanks Meter: 61
If board is able to switch from dfu to recovery without nand soldered, it means that cpu and ram are ok.
Very important: for switch to recovery the board must be powered from battery or power supply.
Otherwise, hard to say what is the cause and usually not fixable.
Old 12-18-2020, 06:58   #6 (permalink)
Crazy Poster
Member: 2964041
Thanks Meter: 3
The error 9 happened on your iPad could result from hardware or software issues, which can usually be solved by hard resetting your iPad, use professional ios repair tools like TunesKit iOS System Recovery and restoring iPad via iTunes.
Please read Fixed: iPad Stuck in DFU Mode to help you get rid of it.
Old 12-18-2020, 06:58   #7 (permalink)
Crazy Poster
Member: 2964041
Thanks Meter: 3
Page generated in 0.13656 seconds with 8 queries
