iPad , iPod , Apple TV iPad 1 , iPad 2 , iPad 3 , iPad Mini , iPad 4 / iPod Classic , iPod Nano , iPod Touch / Apple TV |
02-23-2010, 10:44 | #1 (permalink) |
Junior Member Join Date: May 2008 Location: Hindang, Leyte
Member: 774613 Status: Offline Thanks Meter: 1 | Ipod Expert Need Help I need help to all IPOD Expert. Ipod 2G not detected in Itunes software. The Problem started when i'm trying to update my ipod to latest version. But accidentally while updating process it was suddenly interrupted. And suddenly its not detected to Itunes software i cannot restore it. I'm trying the lower version of Itunes software but the problem still persist. But it was detected in my computer. Im trying toe put the ipod in disk mode but still the problem persist. Any solution to all masters out there!!! Thanks in advance!!!! Here's the screen shot: Itunes software device is not stsected My computer the device is detected |
02-23-2010, 13:54 | #2 (permalink) |
Junior Member Join Date: Jan 2010 Location: London UK
Member: 1218877 Status: Offline Thanks Meter: 3 | Hi First Of All Connect The USB to The iPod & Then Follow These Steps 1. PRESS THE MENU AND MIDDLE BUTTON YOUR IPOD THEN WILL RESTART & YOU WILL SEE THE APPLE LOGO 2. WHEN YOU SEE THE APPLE LOGO RELEASE THE BUTTONS AND THEN PRESS THE MIDDLE AND PLAY BUTTON. 3. YOU WILL THEN BE IN RECOVERY MODE, THE IPOD WILL DISPLAY - "OK TO DISCONNECT" (IF ITS NOT IN RECOVERY MODE THEN REPEAT STEPS 1 & 2) 4. GO TO ITUNES & RESTORE WITH LATEST FIRMWARE Last edited by FineTouchMobile; 02-23-2010 at 14:03. |
02-23-2010, 15:23 | #3 (permalink) | |
Moderator Join Date: Oct 2006 Location: Tunisia Age: 41
Member: 363451 Status: Offline Sonork: 100.1577895 Thanks Meter: 834 | Quote:
that's not recovery mode , it's disk mode | |
02-24-2010, 14:11 | #5 (permalink) |
Member: 1218877 Status: Offline Thanks Meter: 3 | Recovery Mode & Disk Mode Are Similar The Only Difference Is That Disk Mode Only Happens In iPods & Recovery Mode Only Happen In iPhones & iTouch. If Your iPod Is Still Not Detected Then Connect Your iPod Again & Go To Device Manager In My Computer & Find Your iPod & Uninstall All The Drivers. After That Connect Your iPod Again & See If It Gets Detected, If It Doesn't Then Reinstall The Latest iTunes & Try Again If After You Reinstall iTunes & Get The Same Problem Then Try To Format Your iPod In My Computer, If Not Then Try To Do It On A Different Computer |
02-25-2010, 01:14 | #6 (permalink) | |
Member: 774613 Status: Offline Thanks Meter: 1 | Quote:
02-25-2010, 10:35 | #7 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Planet Earth
Member: 79937 Status: Offline Sonork: 100.84313 Thanks Meter: 4,715 | There is no problem to format your iPod, don't worry it will be ok ,will not became worse. After formatting run itunes and restore it. |
02-25-2010, 11:12 | #8 (permalink) | |
Thanks you very much my dear friend and to all who'd reply my thread. Thanks you very much for your effort guys for helping my ipod problem. My ipod is back to normal now... Kindly closed this thread guys...... | |
CDMA EXPERTS NEED HELP 6265 Files | Chandreshswami | Nokia CDMA | 0 | 10-27-2008 15:25 |
phpbb expert need help !! | ..::hotlovercool4::.. | Off Topic Zone | 1 | 06-08-2008 10:44 |
Experts Need Help - Do I need these resistors ? | Seedy | Nokia Hardware & Hardware Repair | 4 | 12-11-2007 10:11 |
Experts Need Help - Do I need these resistors ? | Seedy | Nokia Hardware & Hardware Repair | 1 | 04-12-2007 10:41 |
To Willy Or Other EXPERTS ... Need Help | cellularcareazs | Nokia Hardware & Hardware Repair | 0 | 04-19-2005 06:35 |
