Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 01-28-2010, 17:26   #1 (permalink)
Member: 50700
Thanks Meter: 12
3g no charge no usb solution
1- clean i/o connector flex and pcb connector
2- replace i/o connector flex and pcb connector
3- replace 1 or 2 transistor under shield (check oxy), if no transistor available make jumper.
phone charge @ 290mA , stop charge after 5h, dont get hot and stby time is right.
probably transistor cut power when too hot or someting like.
if solved press thank!!
The Following 5 Users Say Thank You to pinop For This Useful Post:
Old 01-28-2010, 18:17   #2 (permalink)
Member: 50700
Thanks Meter: 12
sorry cant upload...
http://www.allfreeportal.com/imghost..._no_charge.jpg
The Following User Says Thank You to pinop For This Useful Post:
Old 04-27-2010, 17:40   #3 (permalink)
Member: 50700
Thanks Meter: 12
alternativo
http://i39.tinypic.com/10ykggw.jpg
The Following 3 Users Say Thank You to pinop For This Useful Post:
Old 11-24-2010, 18:32   #4 (permalink)
Member: 1450330
What is a "Jumper?" Do I need to sauter a copper wire between the points connected by the green line?
The Following User Says Thank You to spallala For This Useful Post:
Old 02-11-2011, 16:56   #5 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 165
hay i tried this method and it worked but then stopped can anyone tell me what this could be ?? ........................................br
Old 02-11-2011, 17:44   #6 (permalink)
TOZE's Avatar
Member: 54945
Thanks Meter: 22
just rehot all component near dock connector works 100% FOR OUR SHOPS
DONE BY GSM CLINIQUE
The Following User Says Thank You to TOZE For This Useful Post:
Old 02-15-2011, 11:45   #7 (permalink)
Member: 1514552
Originally Posted by pinop View Post
I can't seem to find these connections on my 3G board, are they under the shield?
Old 04-05-2011, 12:42   #8 (permalink)
Member: 535323
Thanks Meter: 3
i make that jumper but when i put on usb on computer usb hub exceeded appear,and than is hot up!
Old 06-25-2011, 16:07   #9 (permalink)
Crazy Poster
Member: 1520911
yes ther are under the shild but at the back of mainbord right side at the bootom
sorry for english! =]
Old 07-12-2011, 23:04   #10 (permalink)
Member: 1614586
Oké, this is not exactly clear for me,
in my case there are transistors in the place of the green line's, do i have to break them away?
And do you mean by replacing the PCB connector, the connector placed on the mainboard or the connector on the ribbon.
Do you mean the components on the mainboard, because there aren't any components visible on the dock connector module
Old 02-09-2012, 12:20   #11 (permalink)
Member: 1672489
Wink many thanks bro. it helps a lot to me:)
Old 10-22-2012, 13:46   #12 (permalink)
Member: 693282
Sonork: 100.1602586
Thanks Meter: 34
100% WorKing
This Guide I 100% Working Well
Thanks Bro
SE K700-500 no charge-joystick-mic solution here.. ufuktakiadam Sony Ericsson Hardware Repair 0 07-08-2009 10:38
C65 no charging need real solution Freshbol Siemens Hardware Repair Area 8 11-13-2007 13:09
W550 no charging, help with solution idhamitov Sony Ericsson Hardware Repair 1 10-24-2006 06:41
Repairing Jxx: zero IMEI, no charging, no net. Chuk Sony 41 08-20-2004 10:06
T28s No Charge, No Network, Dark Displey and no Light Sultan Sony Ericsson Hardware Repair 2 05-15-2002 00:57
Page generated in 0.40802 seconds with 8 queries
