Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 06-18-2012, 13:01   #1 (permalink)
Member: 1198842
Thanks Meter: 162
100% Repair bricked baseband with last Redsn0w
i had one 3GS 32 GB MC141DN , was no IMEI -Wifi-bluetooth- firmaware, where it was happen when the owner try write Ipadbaseband as it is New model of baseband. so i give try and share here what i did and it is success 100%
1- Put Iphone DFU mode, and let Itunes write the firmware 5.1.1.. after itunes finish sending the first stage and it showing itunes verfying the software.. i pluged out the iphone from the PC and closed Itunes. ( iphone will hang on apple logo and install process bar.... from this stage i force it direct to go DFU mode again.
2- run Redsn0w last version, and select ios 5.1.1 and downgrade ipad option and do the rest as usual
3- after finish the process on the iphone it will not run, hang again with apple logo ( because no complete ipsw written on it )
4- i run Redsnow again to as step 2 again with same option ( it will not h arm your device doesnt matter how many time you do it ) to me i just do it 2 time to besure somethings will happen to the baseband firmware..
5- after finish i put the device in DFU mode again and let Itunes flash it again with stock 5.1.1 it finished with out any error and it can aktivated with its original simcard from DE T-Mobile, and unlock the baseband 05.16.05 via T-mobile siside as it is 2 years old..
all thanks and geridet goes to DEV team.
The Following 19 Users Say Thank You to frake50 For This Useful Post:
Old 06-18-2012, 13:06   #2 (permalink)
Registered User
Member: 830204
Thanks Meter: 21
Be sure your tested set is 3GS units manufactured week 34 of 2011 or later. If you have an iPhone3GS and if digits 3-5 of its Serial Number are 134 or later (xx134…)
Old 06-18-2012, 13:08   #3 (permalink)
Registered User
Member: 830204
Thanks Meter: 21
The iPad baseband is not compatible with 3GS units manufactured week 34 of 2011 or later. If you have an iPhone3GS and if digits 3-5 of its Serial Number are 134 or later (xx134…), then you should NOT try to install the 06.15 baseband on your 3GS! It will brick your radio, preventing both the downgrade from working and normal iPhone software from using it as a phone! Be warned!
Old 06-18-2012, 14:33   #4 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,250
Old 06-18-2012, 14:51   #5 (permalink)
Member: 221245
Sonork: 100.1612390
Thanks Meter: 45
some 1 test this solution .???.
Old 06-18-2012, 15:03   #6 (permalink)
Member: 1014826
Thanks Meter: 88
is it true ..if yes then that is big bomb in iphone market
Old 06-18-2012, 15:24   #7 (permalink)
Member: 221245
Sonork: 100.1612390
Thanks Meter: 45
i'm test it error 1013 ??? whith stockfirm 4.1 ????
not work ....
Old 06-18-2012, 19:10   #8 (permalink)
Member: 1198842
Thanks Meter: 162
not work ....
4.1 stock you should PWN it with IREB before restore,, i used the stock 5.1.1
Old 06-18-2012, 21:00   #9 (permalink)
nicacel's Avatar
Member: 111014
Thanks Meter: 132
3GS two years old? ok so no working for device week34 2011 or later...
Old 06-19-2012, 10:48   #10 (permalink)
Member: 1670761
Thanks Meter: 9
hope its has an images before and after the iphone was flashed.
Old 06-19-2012, 11:22   #11 (permalink)
Member: 65548
Thanks Meter: 18
does 32GB contain new hardware??? as far i know only 8GB were contain... please tell me...
Old 06-19-2012, 11:33   #12 (permalink)
Fazil's Avatar
Member: 282757
Sonork: 100.1606418
Thanks Meter: 34
is it Working Anybody tested this solution !
Old 06-19-2012, 11:35   #13 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,250
This is bsht, not a solution .
Old 06-19-2012, 13:23   #14 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 264
2 years old means he just didn't know what to do before,
it is not new baseband and it is not damaged baseband but a software problem only.
it means his 3gs is 2010 model which is supported by downgrade and upgrade of baseband.
Old 06-19-2012, 16:05   #15 (permalink)
Member: 1774069
[IMG]http://www.****************.com/jhkh.gif[/IMG]Thanks for sharing.
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 15:48
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.21440 seconds with 10 queries
