3GS 4.1.2 JB problem I have 3GS 4.1.2 after JB with redsn0w_win_0.9.6b5 (check , Install Cydia and Install iPad Baseband ) after restart phone still only LOGO Apple. If i try to restore origina and custom file OS4.1 only error 3194 I put phone with DFU mode and restore iPhone2,1_4.2.1_8C148a4.2.1Custom_Restore.ipsw and phone sill emergency mode . If i try to JB only Cidia again sill apple LOGO. Maybe anyhelp me |
restore 4.2.1 with itone & then jailbreack & unlock with RedSn0w v0.9.6B5 download here Download RedSn0w_win_0.9.6b5.rar - BitShare.com - Free File Sharing and Storage |
then jailbreak with limera1n then again jailbreak with redsn0w problem solved WBR http://www.mygsmhost.com/images/123123.png |
Step 1: Before doing anything, make sure to read this. Seriously, read it over and over again. There is very important information in there that you must know before proceeding. Step 2: Make sure you have the latest version of iTunes installed on your computer. If not, update iTunes. Step 3: Make sure you have iOS 4.2.1 on your iPhone 3G or 3GS. Step 4: Download RedSn0w 0.9.6 beta 5 as well as iOS 4.2.1 for your iPhone 3G or 3GS from our downloads section. Step 5: Launch RedSn0w and browse for the iOS 4.2.1 firmware you downloaded in the previous step. Step 6: Once the IPSW is identified, click Next. RedSn0w will start preparing the jailbreak data. Step 7: Now make sure you select to “Install Cydia” and “Install iPad Baseband”. A warning will pop up. Again, make sure you read and understand the risks associated with this. Step 8: Make sure your iPhone is turned off and plugged in your computer. If it’s not, plug it in, then turn it off. Click next, and be ready to get your iPhone in DFU mode. Step 9: Hold the Home and Power button together for 10 seconds. Release the Power button while still holding the Home button for a few seconds. Then let RedSn0w run its magic. Done, your iPhone is successfully running a jailbroken iOS 4.2.1, and we have updated the baseband to 06.15.00. If your device is an iPhone 3GS with old bootrom, you won’t have any problem after that. If however it is a newer bootrom, you will notice that you iPhone shows the “connect to iTunes” logo every time you reboot it. It’s normal. While very inconvenient, it’s the way it is. To go around that, launch RedSn0w, plug your iPhone in and select “just boot tethered” just like the image below. It will kick boot your iPhone. http://i53.tinypic.com/2582ipd.jpg |
Download iOs4 4.1 edit your host put this in lower of host using notepad " 74.208.10.249 gs.apple.com " then shift restore in original 4.1 then jailbreak using redsn0w_win_0.9.6b5 if you got problem using restoring Error 1015 you can use RecBoot 1.0.1 or Tiny Umbrella ( Kick Recovery Mode ) now if you got Error 3194 maybe you shsh file not save before 4.1 ,... br JaYTreze |
Yes !!! For new bootrom to this time only “just boot tethered” work solution. |
yes shsh file not save this person |
