Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 11-19-2009, 11:44   #1 (permalink)
yousha's Avatar
Member: 17689
Sonork: 100.72392
Thanks Meter: 737
3GS Always in Recovery mode after Reboot
its a NEW IBOOT VERSION when you run blackra1n on it it will make the handset JAILBROKEN but (tethered jailbreak)
Now the question is
What is this Fcuking TETHERED JAILBREAK?
Simple Answer :TETHERED JAILBREAK is you need computer everytime when you need to reboot your phone and run blackrain everytime to reboot it properly and moreover its not a BUG in blackra1n it FEATURE this problem occures mostly on the OTB 3.2.1
Read the MASTERS BLOG AGAIN and use your MIND
http://iphonejtag.********.com/
if your ipt2/3GS/ipt3 is rebooting into recovery after running blackra1n, this isn't a bug. It's a feature. You need to run blackra1n every time to boot it. This 'feature', called tethered jailbreak, is enabled by upgrades Apple made to the bootrom and the fact ipt3 uses nand flash.
The Following 94 Users Say Thank You to yousha For This Useful Post:
Old 11-19-2009, 13:03   #2 (permalink)
Member: 90701
Thanks Meter: 134
iPhone 3gs goes recovery mode while trying to restore comstom file
Now the question is
Well, thatnks for the post. But may be I was unable to make you understand that the recovery mode I ahve in my iPhone is not after blackrain, blackrain goes fine, i got jailbreak and activated too, but when I try to restore custom firmware(in order to unlock) than I get 1604 error, not only that even if I don't go for restore when I restart the phone just goes recovery mode and thats it, I have to restore again with original file. Hope you understand now. Done many iPhone but never got anything like this.
Old 11-19-2009, 13:18   #3 (permalink)
yousha's Avatar
Member: 17689
Sonork: 100.72392
Thanks Meter: 737
First clear it which phone you are using if its IPHONE3G-S than the above stated problem have no solution till yet if you have IPHONE2G OR 3G than you can try to recover it from I-RECOVERY CONSOLE
http://www.mediafire.com/file/ywhxqz...%20&%20Mac.rar
WIN-XP
1=INSTALL libusb-win32-filter-bin-0.1.12.2.exe
2=START-->RUN-->iRecovery.exe -s(with proper path and handset should be in recovery mode)
3=type these commands as it is
setenv auto-boot true
saveenv
reboot or fsboot (one of them)
The Following 13 Users Say Thank You to yousha For This Useful Post:
Old 11-19-2009, 13:36   #4 (permalink)
Member: 90701
Thanks Meter: 134
WIN-XP
saveenv
Well, it is 3gs as i said on the header.
Old 11-19-2009, 13:48   #5 (permalink)
yousha's Avatar
Member: 17689
Sonork: 100.72392
Thanks Meter: 737
in iRecovery, type
printenv
Copy the result and Post here or Alternativly you can yourself see the AUTO-BOOT flag is set to TRUE or FALSE .If it is set to "false" that needs to be changed to "true" (auto-boot="true"). Do this by typing:
setenv auto-boot true (but i highly doubt its the case with 3G-S)
let me know the result i am here
Old 11-19-2009, 13:57   #6 (permalink)
Member: 90701
Thanks Meter: 134
in iRecovery, type
printenv
Hi, Thanks for your effort of helping me. Nop can't even go there as you said. But I think I will be able to unlock with wi-fi. Have to try it later. problems come only if I restart or reboot or take off the sim. Also I think this happened casue the phone was updated directly with itunes and created by apple.
Old 11-19-2009, 14:05   #7 (permalink)
yousha's Avatar
Member: 17689
Sonork: 100.72392
Thanks Meter: 737
My problem for now is i am not having the similar problem handset in hand otherwise i would be testing tons of things over it i have in my mind right now if anyone having the similar problem in IPHONE3G-S only can contact me on MSN or Whatever messenger probably we could fix it
wbr
y0
Old 11-19-2009, 14:13   #8 (permalink)
quickgsm's Avatar
Member: 414755
Sonork: quickgsm
Thanks Meter: 389
My problem
http://forum.gsmhosting.com/vbb/showthread.php?t=859738
Old 11-19-2009, 17:04   #9 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
I think there are several such threads.No need to make a new one.Waiting for sn0wbreeze
Old 11-20-2009, 18:39   #10 (permalink)
.:Morpheus:.'s Avatar
Member: 47774
Thanks Meter: 185
Note: sn0wbreeze will NOT make a MC iPod Touch 2nd/3rd Gen or iPhone 3G[S] w/new Bootrom Untethered!
Old 11-21-2009, 09:31   #11 (permalink)
yonylove's Avatar
Member: 279453
Thanks Meter: 29
Check the serial # of the phone under Settings | General | About. If the 4th and 5th digit of the serial is "40" or higher, then you got a phone with the new iBoot and will require this each time its rebooted, unless/until someone comes up with a way to hack this in the future. And this applies if you use BR1 or PwnageTool/custom IPSW to JB. No tools exist currently to get around this.
Old 11-21-2009, 13:41   #12 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Tethering is a feature I think by the time there will be a solution for that.About sn0wbreeze I know that.
Old 11-21-2009, 20:19   #13 (permalink)
YasinŽ's Avatar
Member: 489622
Thanks Meter: 435
We have to wait untill new Jailbreak from Dev team ??
Old 11-21-2009, 21:01   #14 (permalink)
powerplay83's Avatar
Member: 753732
Thanks Meter: 252
thats right we have to wait for new Update
The Following User Says Thank You to powerplay83 For This Useful Post:
Old 11-22-2009, 08:10   #15 (permalink)
yousha's Avatar
Member: 17689
Sonork: 100.72392
Thanks Meter: 737
Its true the models having serial above than 42xxx have this problem and i have tested that lower serial can be fixed with I-RECOVERY TRICK if anyone having similar problem please contact me for some safe tests
The Following 5 Users Say Thank You to yousha For This Useful Post:
Without problem "ALWAYZ recovery mode after reboot with Blackra1n" anpha72000 iPhone 2 / iPhone 3G / iPhone 3GS 1 01-27-2010 10:16
Recovery mode after reboot coeugh iPhone 2 / iPhone 3G / iPhone 3GS 5 01-07-2010 01:03
3GS stuck in recovery mode after power on leebok iPhone 2 / iPhone 3G / iPhone 3GS 7 12-06-2009 17:12
After jailbreakin iphone 3GS still in recovery mode xpcenter iPhone 2 / iPhone 3G / iPhone 3GS 2 11-11-2009 06:50
Page generated in 0.25321 seconds with 11 queries
