Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 02-07-2015, 16:27   #1 (permalink)
Member: 63172
Thanks Meter: 22
3GS always serching after 6.1.6 jailbreak and unlock
Hi anyone, iphone is constantly searching for network. Any ideas please?
Old 02-07-2015, 16:46   #2 (permalink)
Member: 63172
Thanks Meter: 22
After untethered jailbreak with redsn0w it was fine. Used ultrasn0w 128 now continually searching....
Old 02-07-2015, 16:48   #3 (permalink)
papoo's Avatar
Member: 188374
Sonork: 1000.2
Thanks Meter: 203
If U Jailbreak Ur Device Correctly .Then This Is Hardware Problem...
Old 02-07-2015, 16:50   #4 (permalink)
papoo's Avatar
Member: 188374
Sonork: 1000.2
Thanks Meter: 203
Can you Explain Your Jailbreak Procedure.
Old 02-07-2015, 16:55   #5 (permalink)
Member: 63172
Thanks Meter: 22
I went through the process..
http://forum.gsmhosting.com/vbb/f852...xspwn-1786325/
which worked ok. And signal was working ok. Then Cydia/Ultrasn0w
Now searching...
Old 02-07-2015, 17:12   #6 (permalink)
Member: 63172
Thanks Meter: 22
think i may have discovered the problem - I didnt change to ipad baseband...
Old 02-07-2015, 17:14   #7 (permalink)
papoo's Avatar
Member: 188374
Sonork: 1000.2
Thanks Meter: 203
iphone 3gs 6.1.6 untethered jailbreak unlock susesfull
iphone 3gs 6.1.6 jailbreak unlock susesfull
3gs iPhone2,1_6.1.6_10B500_Restore untethered jailbreak & unlock
1) Restore your device with iPhone2,1_6.1.6_10B500
2) Jailbreak
2.1) Open redsn0w_win_0.9.15b3
2.2) Go to extra
2.3) Go to select ipsw
2.4) Select iPhone2,1_6.0_10A403_Restore
2.5) Back
2.6) Jailbreak
2.7) Next, follow the instructions to enter dfu mode
2.8) Check install cydia & install ipad baseband
2.9) Wait until jailbreak done
3) There will be no cydia in your device
3.1) Open redsn0w_win_0.9.15b3
3.2) Go to extra
3.3) Go to select ipsw
3.4) Select iPhone2,1_6.0_10A403_Restore
3.5) Go To Just boot
3.6) Follow the instructions to enter dfu mode
4) after device on u can see cydia
5) Open Cydia.
6) Click the "Changes" tab in the footer.
7) Press the "Refresh" button in the top left corner.
8) After "Reloading Data", perform a search for "p0sixspwn" (the O is a zero).
9) Tap Install.
10) After installing p0sixspwn your device is untethered
11) Install ultrasnow 1.2.8
1000% network done
Report Post
Old 02-07-2015, 17:18   #8 (permalink)
papoo's Avatar
Member: 188374
Sonork: 1000.2
Thanks Meter: 203
IF Not Solve Confirm Hardware Problem Check Cr Connector Antina Pad etc
Old 03-09-2015, 15:34   #9 (permalink)
Member: 1722472
Thanks Meter: 3
what is your baseband?
Page generated in 0.13504 seconds with 8 queries
