01-02-2009, 20:57 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | Iphone unlocked and no signal Pls advice to solve this trouble BR, Tito Millo |
01-02-2009, 21:13 | #2 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: Chernobyl Age: 46
Member: 132870 Status: Offline Thanks Meter: 36 | hi Quote:
only you ? | |
01-02-2009, 21:19 | #4 (permalink) | |
Freak Poster Join Date: Jul 2006
Member: 321752 Status: Offline Thanks Meter: 28 | unlock http://forum.gsmhosting.com/vbb/show...=659395&page=2 check tht post Quote:
01-02-2009, 23:20 | #8 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | yellowsn0w third generation |
01-02-2009, 23:52 | #9 (permalink) |
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | This is a problem on application not with us the unlockers i guess DEV Team will do something about this hope their soon reply, hope this weekend they fix this or if is possible pls upload an older version on source links not 0.9.4 cuz its not working well BR, Tito Millo |
01-02-2009, 23:57 | #10 (permalink) |
Member: 321752 Status: Offline Thanks Meter: 28 | once more 1. Restored Firmware from Itunes (Firmware 2.2) 2. Jailbreak Iphone with Quickpwn 3. Connect Iphone to PC and wait for Itunes to pick it up 4. Run Iphone3gunlock by HACX 5. Select Single-Shot 6. Turn off Iphone 7. Turn back on Iphone and insert any active sim card 8. It should not show any signal. 9. Wait for Iphone to lock the screen and the wait for 2 minutes 10. Remove Sim tray 11. Unlock screen 12. Replace sim tray and you should see a network. Failing that none of this worked reset your iphone and start again. I TRYD UNLOCKING 9 PHONES NOW AND SHOWS ME 100%SUCCESS TRY IT ONCE MORE WHILE DOING THS U MUST OFF THE 3G OPTION AND DATA ROAMING OPTION DONT FORGET TO RESET NETWORK SETTINGS |
01-03-2009, 00:04 | #11 (permalink) |
No Life Poster Join Date: Dec 2006 Location: NYC
Member: 416710 Status: Offline Thanks Meter: 391 | Quote: |
01-03-2009, 00:06 | #12 (permalink) | |
01-03-2009, 00:13 | #13 (permalink) |
Freak Poster Join Date: Apr 2007 Location: the Land of the Cedars
Member: 497776 Status: Offline Thanks Meter: 38 | this way u can make call , out\in calling i try this way also worked (1) Restoring the Itunes with Firmware 2.2 (2) QuickPwn 2.2 with the Firmware 2.2 (3) Installing Yellowsn0w with cydia http://apt9.yellowsn0w.com (4) Install Bossprefs with Cydia (then Reboot) & Update Cydia in the process!! It will reboot . (5) Resetting network = setting ,general , reset , reset network setting (6) Take the SIM at the time of the screen appears Unlock (7) Wait a while (30-60 seconds) and insert the sim card (8) Install the Mobile Terminal in Cydia (9) Enter mobileterminal yellowsn0w in yellowsn0w-r-c (10) Go on airplain mode(on) wait 10 sec then (off) (11) good luck B.R Normandy |
The Following User Says Thank You to vistaunlock For This Useful Post: |
01-03-2009, 01:35 | #14 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Shenzhen China Age: 68
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | wait for 60sec after reboot than take out card and put back is verry impprtant at this stage. Before I also didn't have network signal, so I stop being smart and follow instruction stepbystep. Guess what .... It worked |
01-03-2009, 01:42 | #15 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: sn,fdo,lu philippines
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | Quote:
br keaelite | |
Iphone 2.21 modem 3.30 unlocked but no signal | mobile_juice | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 02-23-2009 11:38 |
iphone 3g softbank japan unlock but no signal help | ryukie78 | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 01-02-2009 19:47 |
*** iphone 3g unlocked but no Signal *** | Nurein | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 12-29-2008 06:48 |
Iphone V.1.1.3 16g Unlocked But No Signal!!! | Hard Stone | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 02-22-2008 21:20 |
3390 unlocked and No signal | Black-Axe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-02-2002 19:21 |
