Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 01-02-2009, 14:27   #1 (permalink)
hema's Avatar
Member: 19267
Thanks Meter: 101
dev team updated yellowsn0w 9.4.0 with cydia
[Tutorial] 3G Unlock method that works
UPDATE. Dev Team have Updated the yellowsn0w newest version is 9.4.0 throgh cydia. Thanks dev team!!! great work.
Here you have to wait affter reset 5-10 secs and turn the phone to airplane on wait 2 sec and turn it off.
Next i'm waiting to see if this works allso if the network loses coverage and you get no service if not do
go to terminal
type yellowsn0w -c
type yellowsn0w -r
type yellowsn0w -q
airplane mode on
airplane mode off
And it's up again.
If the new update doesnt work with only airplane on and off follow this tutorial.
If done exactly as told it works for most of the user.
1. recover your iphone to 2.2 with bb 2.28.00 affter ready close itunes dont sync, activate or nothing just close it!!!
2. quickpwn it with installer and cydia installed
3. when phone is ready connect to wifi,got to cydia, when opend for the first time ignore the update for cydia
and install first mobileterminal and affter sbsettings from cydia.
4. turn off data roaming and 3g connection from settings !!!!!
5. install yellowsn0w from cydia affter adding the source http://apt9.yellowsn0w.com offcource
5. slide ur finger from top left to right on the screen to get sbsettings open
6. press power button from sbsettings and from the popup restart button.
7. when phone is reset wait for 20-30 secs and go to mobile terminal
8.
Go to terminal
type yellowsn0w -c
type yellowsn0w -q
airplane mode on
airplane mode off
if you get "open: Recource busy" just repeat the command where you got it from.
if command yellowsn0w -q keeps loading for more than 20sec and your terminal looks similar to pics from http://www.flickr.com/photos/33360882@N08/ move to next step.
9. Go to setting turn airplane mode on wait 10 secs and it should start searching for the network, it shold find the network and everything should be ok.
If not
if it still show the four dots for the signal repeat the steps 8 and 9 but first exit mobile terminal totaly by holding down the home button until it closes totaly
if that doesnt work eather use
compination
go to terminal
type yellowsn0w -c
type yellowsn0w -r
type yellowsn0w -q
airplane mode on
airplane mode off .
That's how you get it working for 99% sure. i tried it in 3 diferent iphones one from finland one from germany and one from UK. UK and german wasnt workin in the first.
Until now many has goten it to work only by this method.
UPDATE.
I can confirm I got it allso to work with out sbsettings reset, just usual phone on and phone off.
UPDATE.
So only thing you have to actualy do is to install yellowsn0w from installer not from cydia. And after every time the phone boots wait 30 secs and make the commands with mobile terminal(step 8)-> and airplane on off, if doesnt work repeat the step 8 and again airplane on off.
UPDATE.
If you lose network use this compination and you'll get network back without reseting the phone
go to terminal
type yellowsn0w -c
type yellowsn0w -r
type yellowsn0w -q
airplane mode on
airplane mode off
courtesy: http://hackint0sh.org/forum/showthre...t=61827&page=4
rgds
The Following 3 Users Say Thank You to hema For This Useful Post:
Old 01-02-2009, 15:26   #2 (permalink)
Member: 739410
Thanks Meter: 88
terminal need wifi or working widout wifi ??
Old 01-02-2009, 15:50   #3 (permalink)
eddiŽ's Avatar
Member: 10776
Thanks Meter: 240
with WIFI only.......
Old 01-02-2009, 16:07   #4 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 190
I dont understand what is terminal ? help please.
Old 01-02-2009, 17:37   #5 (permalink)
lypen17's Avatar
Member: 44223
Thanks Meter: 20
this solution dont work lose network after some minutes (no service) ,anyone tested 100% and stable solution ?????? a think i dont understand at ..iphone.unlock.no till some days ago was writen that dev team have found the solution but who have updated the iphones to 2.2 does wait for long time etc etc now the solution need only the 2.2 and new baseband ????????????
Old 01-02-2009, 20:01   #6 (permalink)
Member: 321752
Thanks Meter: 28
thts an application
terminal thts an application whtch u can download it from cydia,its just like windows dos prompt.to install terminal install mobile terminal from cydia.
Old 01-02-2009, 20:03   #7 (permalink)
Member: 321752
Thanks Meter: 28
it works
sorry brothr his solution works and my all cstmrs r satisfied ,thy still having full network and not facing any problems
Old 01-02-2009, 23:24   #8 (permalink)
Member: 318299
Thanks Meter: 8
thanks to all .... after several attempts to unlock it to my attention ... iphone 3g error gave me because my SIM card was with pin, we have to get the PIN code is very important
iPhone Dev-Team Releases PwnageTool 3.1.3 With 3GS Jailbreak Support!!!!!!!!!!!!!!!! tellissi20 iPhone 2 / iPhone 3G / iPhone 3GS 26 10-03-2009 16:28
iPhone Dev-Team Jailbreaks iPhone OS 3.0 malikkk iPhone 2 / iPhone 3G / iPhone 3GS 5 04-04-2009 20:28
Dev Team Updates Progress On 3G Unlock malikkk iPhone 2 / iPhone 3G / iPhone 3GS 2 10-07-2008 02:41
DEV TEAM UPDATE >>>PwnageTool 2.0.3{mac} ***&*** QuickPwn {windows} malikkk iPhone 2 / iPhone 3G / iPhone 3GS 35 10-06-2008 07:45
Page generated in 0.18689 seconds with 9 queries
