03-03-2013, 08:53 | #94 (permalink) |
Freak Poster Join Date: Feb 2013 Location: ..::Pakistan::.. Age: 32
Member: 1878900 Status: Offline Thanks Meter: 121 | Step 2 : Open redsn0w_win_0.9.15b3 Step 3 : Extras > Select IPSW > iPhone2,1_6.0_10A403_Restore > Open Step 4 : Back > Jailbreak Step 5 : Select install ipad baseband & unselect install cydia > next > put dfu mode (redsnow instruction) after reboot phone will activated Step 6 : Open evasiOn 1.4 and press jailbreak (for untethered your jailbreak ) |
03-06-2013, 18:44 | #97 (permalink) |
Junior Member Join Date: Feb 2007
Member: 447877 Status: Offline Thanks Meter: 0 | thank you working ok needs clean install for 6.1.2 from itunes the fetch 6.15 baseband with out cydia from redsnow with 6.0 firmware selection then evison 1.5 to jailbreak install ultrasnow direct from cydia working |
03-08-2013, 02:37 | #99 (permalink) |
Junior Member Join Date: Sep 2012
Member: 1810311 Status: Offline Thanks Meter: 0 | Worked like a charm! Everything worked here using this method 100%. Just a question to some of you though in this same scenario with a 3GS and new bootrom. Would I just perform the baseband downgrade process after installing the ipad baseband and everything should work via the same method? Does anybody else find this to be a pain in the *** every time new firmware is released? I'm seeing forum posts in my dreams now. Damn you Apple!! |
03-08-2013, 18:37 | #100 (permalink) |
Junior Member Join Date: Nov 2008 Location: Dhaka
Member: 901332 Status: Offline Thanks Meter: 0 | 3gs unlock help? i tried but failed show in redsnow when run . please help .. is it snowbreze need to do it? is it restore by orginal 3gs 6.1.2 firmware restore to do? |
03-09-2013, 06:36 | #101 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: In Your Heart
Member: 451538 Status: Offline Thanks Meter: 98 | Quote:
[email protected] | |
03-09-2013, 06:40 | #102 (permalink) | |
no need of sn0wbreze,install stock ios(6.1.2) and repair ipad baseband with redsn0w (6.15) and copy paste deb files via itools(i used) restart two times with sim card,thats all. post reply if not worked on buzz me on yahoo. [email protected] | |
03-09-2013, 19:03 | #104 (permalink) | |
Member: 1878900 Status: Offline Thanks Meter: 121 | Quote:
Step 1 : Restore latest version iPhone2,1_6.1.2_10B146_Restore ( after restore phone will in activation mode) Step 2 : Open redsn0w_win_0.9.15b3 Step 3 : Extras > Select IPSW > iPhone2,1_6.0_10A403_Restore > Open Step 4 : Back > Jailbreak Step 5 : Select install ipad baseband & unselect install cydia > next > put dfu mode (redsnow instruction) after reboot phone will activated Step 6 : Open evasiOn 1.4 and press jailbreak (for untethered your jailbreak ) Step 7 : Download ITOOLS & Ultrasn0w 1.2.8 Step 8 :After complete jailbreak open ITOOLS Step 9 : connect phone to pc and open file system >var>root>Media>Cydia>AutoInstall (If Cydia & AutoInstall don't exist, create these folders as posted) Step 10 : place the All DEB files(ultrasn0w 1.2.8) Step 11 : And reboot phone normaly Step 12 : After reboot your phone is UNLOCKED | |
