Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
View Poll Results: Useful?
Yes 0 0%
No 0 0%
Voters: 0. You may not vote on this poll
Old 05-18-2011, 13:58   #1 (permalink)
Member: 186734
Thanks Meter: 165
EasyJailbreakBatch Tool by zeezoo
EasyJailbreakBatch Tool is a little dos-batch based program to make jailbreaking process a bit easier.
What that program does?
This little tool helps you with jailbreaking Apple's iDevices, such as iPhone, iPod and iPad...
Once installed will download all required files to instalation folder. After that you just have to choose which iOS version your iDevice is running on and then my software will find out and download redsn0w which supports chosen model and iOS.
You can also check which version is your phone running on by typing f and pressing [enter] - f0recast software used. This tool will get for you always the latest available version.
Also if required .ipsw doesn't exist in default apple folder or in ipsw folder my tool will get the iOS directly from apple server. Please copy/move all .ipsw to iPhone/ipsw folder, as all older versions are deleted by iTunes when new iOS is released.
Please make sure that You have chosen the right iOS and right model. Otherwise it may broke iPhone software and you will have to restore your device to stock firmware (usually the latest if SHSH blobs not saved)
Please use upd8.exe file to download software from my private server. Every time you run upd8.exe will delete old executable and get new one for you.
Notice:
For iPhone 2G 3.1.2/3.1.3 you will need to point for the .ipsw manually as commandline is not implemented in redsn0w-win_0.9.4.
Program will get both bootloaders required and correct redsn0w version.
All redsn0w versions are stored on my private server. I couldn't manage to make the software getting them from official links but they are untouched.
No viruses or other malware. All files checked with AVG antivirus.
Software was made to help and make whole process easier and quicker.
Anyway I'm not taking any responsibility. If anything goes wrong don't sue me
I'll do my best to keep software updated when new iOS and redsn0w is released.
EasyJailbreakBatch Tool by zeezoo - Info | Facebook
Download:
upd8.exe will download always the latest version. Then use exe file from iPhone folder on your desktop.
Please give me ideas what I can add to the software or what to change/fix.
If anyone needs it and can provide that list it would be great.
update:
if you want to update program to the latest version just type u and press [enter] or download upd8.exe again and start it - will get for you the latest available version
zeezoo
PS. I'm looking for a little tool which can print in commandline just few information about connected iDevice... I've been trying to do it by myself but I'm not a programmer. If anyone can help me with that or make this tool for me would be great. All I need is to print in commandline iDevice, model and iOS version, so I can make my software to detect what's connected to the computer and then start proper redsn0w version.
Thanks for that in advance.
changelog:
2.7
-added support for TinyUmbrella
will check for latest available version, get it for you and run it
-"Checking for update" loop fixed - temporary fix, cause I still didn't get the answer from RotKT. Anyway once checked will skip checking until you run the program again.
2.6
-added support for iOS beta 5
-added redsn0w_win_0.9.8b5
2.5
-added support for iOS beta 4
-added redsn0w_win_0.9.8b4
2.4
-added switches
few examples for Jailbreaking process:
EasyJailbreakBatch /m iPhone 4 4.3.3
EasyJailbreakBatch /m iPhone 3GS 4.3.4
EasyJailbreakBatch /m iPad 1 5b3
few examples for Boot tethered process:
EasyJailbreakBatch /b iPod 4G 5b3
EasyJailbreakBatch /b iPhone 4 4.3.4
for more info run EasyJailbreakBatch /h
Software will get redsn0w and ipsw file and then start jb/boot tethered procedure without any typing, so from now you can make shortcut on your desktop to quickly start jailbreaking or booting popular iDevices
2.3
-will use redsn0w_win_0.9.6rc18 for iPhone 3GS 4.3.3, cause redsn0w_win_0.9.6rc19 doesn't do iPad baseband update
-added support for 4.3.4 [tethered] & boot tethered iDevice of course.
-added redsn0w_win_0.9.8b3
2.2
-added option to boot tethered iOS 5beta 1,2,3 devices. Supported devices:
iPhone 3GS
iPhone 4
iPod 3G
iPod 4G
iPad 1
2.1
- redsn0w_win_0.9.6rc19 added
- redsn0w_win_0.9.8b2 added
- will start redsn0w_win_0.9.6rc19 to jailbreak iOS 4.3.3 & 4.2.8 (VERIZON)
- iOS 5b3 support added [tethered jailbreak]
- little change log added
2.0
-added auto-update option
you can switch on/off from configuration menu if any problems.
default is off
-rebuilded upd8.exe file [please don't use file from 1st post in this topic until they allow me to edit and update it]
added installer - you can choose where to install this software
to do that just get upd8.exe from this post and run it.
1.9
-added option to change colors
goto configuration and you can choose the colors for the background and font
-added option to type iDevice,model and version
for example you type:
iPhone 4 5 and script will find correct redsn0w for your phone and start it
few other examples:
iPad 1 4.3.3
iPhone 2G 3.1.2
ipad 1 4.2.1
ipod 3g 4.3.3
iPod 4g 4.3.3
1.8
-added support for Verizon iPhone 4 4.2.8 untethered jailbreak
-added "reset to default" option for hosts file
-added redsn0w_win_0.9.6rc18
1.7
-added new version of wget
You can choose to resume broken downloads now instead of deleting ipsw file and getting complete one.
Works much faster as well.
-added more options in configuration
you can set how often script will check for update. 1-9 days
-Some minor fixes to improve stability.
1.6
fixes
- iPhone 3G 4.2.1 and 3GS 4.2.1 didn't work properly. That's fixed now.
- there was a little problem if date was in different format than yyyy/mm/dd
now should work fine even if it's dd-mm-yyyy
new
- micro Apache web server added for following phones:
iPhone 3G 4.2.1
iPhone 3GS 4.2.1,4.3.1,4.3.2,4.3.3
It will save you time and bandwith. You just have to put iPad1,1_3.2.2_7B500_Restore.ipsw in ipsw folder. If you don't have that file on you hdd script will get it for you automatically.
And then...
1. Will add special line in hosts file - it will be deleted when redsn0w operations are finished.
2. Will download micro Apache from my server with all required settings.
3. micro Apache server will start on port 13000 (if this port is used with another application will not work properly - please let me know if you have any problems with that. I will change it to different one)
4. Script will start rinetd service to bind port 80 to 13000. If you see any errors please let me know. In my case there was a problem with teamviewer on one of 5 computers which I've used for tests. I've closed it any works fine.
5. redsn0w will start and will think that is downloading iPad baseband from appldnld.apple.com but it will be your private http server
6. After redsn0w finished work hosts file will be restored and micro Apache server will be terminated.
You and your files are safe
1.5
-iOS 5b1 support added for:
iPhone 3GS
iPhone 4
iPod Touch 3G
iPod Touch 4G
iPad 1
[tethered jb only]
-program will check for update once a day, not everytime when opened/closed
-some little changes in code - should work faster now
1.4
-hosts file editor added
will check if gs.apple.com line exist in hosts file and if not will add otherwise will ask to remove it.
after any operation will ping gs.apple.com to test if it's changed correctly.
after first run will make backup of hosts file, can be restored any time
1.3
changes:
-batch didn't work properly if Windows was non-english language. That's fixed now.
-batch is using latest redsn0w_win_0.9.6rc17 for 4.3.3 firmware
anyway you can still use rc16 if you use manual mode
-added option to start redsn0w manually
of course if it's not on the hdd will download selected version
-added option to set ipsw folder manually
if you have ipsw files downloaded already and you don't want to move them to ipsw folder just type c [enter] and set the correct folder
That will be saved in config file to use in the future. Of course can be changed anytime.
1.2
changes:
-added support for iPod 2G 4.2.1
-added support for iPod 3G 4.2.1/4.3.1/4.3.2/4.3.3
-added support for iPod 4G 4.2.1/4.3.1/4.3.2/4.3.3
-added support for iPad 1 4.2.1/4.3.1/4.3.2/4.3.3
1.1
- I didn't notice before that iTunes keeps only the latest software in default ipsw folder. From now my program is checking default folder and if it doesn't find correct file it will check ipsw folder located in iPhone folder on desktop and if it doesn't find it there it will get it from apple server.
To get new executable please use upd8.exe or type "u" in batch window and press enter. Anyway program will show that there is update available and give you instructions.
1.0 initial version
- iPhone iOS supported models and versions
2G 3.1.2/3.1.3
3G 4.2.1
3GS 4.2.1/4.3.1/4.3.2/4.3.3
4 4.2.1/4.3.1/4.3.2/4.3.3
-f0recast version 1.2
The Following 63 Users Say Thank You to zeezoo For This Useful Post:
Old 05-18-2011, 15:52   #2 (permalink)
Member: 468632
Thanks Meter: 60
good job bro i am so appreciate..............
Old 05-18-2011, 17:13   #3 (permalink)
Member: 186734
Thanks Meter: 165
version 1.2 available.
changes:
type u in the main menu and press [enter] or use upd8.exe to get the latest executable.
zeezoo
The Following 6 Users Say Thank You to zeezoo For This Useful Post:
Old 05-18-2011, 19:59   #4 (permalink)
ebu mohammed-emin's Avatar
Member: 263993
Sonork: 100.1612432
Thanks Meter: 173
we have test it
br....
Old 05-19-2011, 10:29   #5 (permalink)
Registered User
Member: 773639
i dont understand what is the use and how to use
Old 05-19-2011, 10:51   #6 (permalink)
Mohsin_josh's Avatar
Member: 78884
Sonork: mohsin111
Thanks Meter: 92
goood job i hope u will done next update remaning model version
keep it up
br
mohsin
Old 05-19-2011, 12:44   #7 (permalink)
royal_electronics's Avatar
Member: 397892
Sonork: 100.1609899
Thanks Meter: 190
Arrow
good job sir & thanx for sharing.also waiting for tested reply any body ????
Old 05-19-2011, 19:25   #8 (permalink)
muhned's Avatar
Member: 201469
Sonork: software
Thanks Meter: 50
who test it
is the method success or not
Old 05-21-2011, 14:26   #9 (permalink)
Member: 5778
Thanks Meter: 10
this program is like book (( jailbreak for Dummie's ))
nice works man
thanks
Old 05-21-2011, 15:10   #10 (permalink)
Member: 707419
Thanks Meter: 6
A suggestion would to display which redsnow you want and give the option to download redsn0w and custom firmware instead of downloading automatically.
All i wanted to know is which redsn0w to use as already had custom firmware but the program automatically downloaded custom firmware which i didnt want it doing
My opinion. have following options
1) download files and start process
2) exit
Old 05-21-2011, 15:32   #11 (permalink)
Member: 186734
Thanks Meter: 165
Originally Posted by rafiqcell
good work but not Easy jailbreak
I don't get it - what's complicated for you?
That was the idea. Easy jailbreak. Not need to search for proper redsn0w for iOS. I'm glad you like it.
2) exit
1. My program is to make jailbreaking easier. Not to choose which version of redsn0w you want to start. You can do it manually.
2. redns0w requires to have original iOS firmware, not custom. If You copy required firmware to Desktop/iPhone/ipsw folder my program will not download new original iOS from apple server.
3. Maybe I'll add some instructions which redsn0w you have to use for specified iOS soon but it's not really needed if you know iOS version.
The Following 4 Users Say Thank You to zeezoo For This Useful Post:
Old 05-21-2011, 22:01   #12 (permalink)
hack team's Avatar
Member: 118806
Sonork: 1575714
Thanks Meter: 20
great tool to safe time
keep it
Old 05-22-2011, 01:57   #13 (permalink)
Member: 27854
Thanks Meter: 8
please make option if u want to download files, since most ppl have lots of iphone files on their pc already, it is a waste of time and bandwith to download files again.
otherwise very good program, tnx
Old 05-22-2011, 07:54   #14 (permalink)
eyestrain's Avatar
Member: 237911
Thanks Meter: 632
If you'd like to get source for it just PM or e-mail me. I don't have any problems if You want to check it out.
hi sir,
i like the idea,
can you send me how you have done this?
i have a lil idea but its not enough,
and if ever ill make another program with your idea, i will grive credits
just kiddin,
i just like to know how'd you did that
btw,
nice tool
regards
Old 05-22-2011, 11:38   #15 (permalink)
akadhitz's Avatar
Member: 1017750
Sonork: 100.1624716
Thanks Meter: 58
i like this tool, thanks for sharing....
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.30085 seconds with 12 queries
