02-15-2013, 12:06 | #1 (permalink) |
Junior Member Join Date: Mar 2007
Member: 472557 Status: Offline Thanks Meter: 0 | Error 1015, Iphone 3G, 8GB I know this has been asked before, i read some of the guides here, but i cannot escape this. So far this is what i managed to do: 1. Run Redsn0w 0.9.6b5. - done 2. Browsing & select 4.1 or 4.2 firmware. - done 3. The new message box will pop up so click YES. - i don't know what message box ... 4. Click next. - done 5. just enter pwned DFU mode right now. - done 6. then open itunes 10.1 - done 7. shift and select oficial frimwar 4.1.restor.u got error - done 1015 nd iphone already in recocery - done 8. open RecBoot. _V 1.1 Run Exit.Bat . it will - done complete and screen Emergency Call Mode. - done 9. Run Redsn0w 0.9.6b5. - done 10. Browsing & select 4.1 firmware. -> STILL OFFICIAL FIRMWARE ? 11. The new message box will pop up so click YES. 12. Click next. 13. don't tick install ''updat ipad basebande''.only ''instal cydia'' done .complete and screen Airplane Mode. -> IN THIS STEP I ONLY CHOOSE Cydia? - AFTER I DID THIS, Pineapple showed up. and i think finished, but i am still in recovery WHAT DO I DO NEXT? ------- 14. Again Open Redsn0w 0.9.6b5. 15. Browsing & select 4.1 firmware 16. The new message box will pop up so click YES 17. Click next 18. Check on INSTALL CYDIA and INSTALL IPAD BASEBAND 19. Again new message box will pop up so click YES 20. Click next 21. Follow introduction for DFU 22. Jailbreak Done ! 23. Extract Unlock 06.15 Without wifi and open Unlock.bat 24. Reboot Device 25. Unlock Done ! |
02-15-2013, 12:20 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: INSIDE OUT
Member: 1015414 Status: Offline Thanks Meter: 155 | use IREB to fix ur problem you can find here https://www.google.com.ph/webhp?hl=fil&tab=ww check this http://www.youtube.com/watch?v=lKkront2s_0 |
02-15-2013, 12:45 | #4 (permalink) |
Member: 472557 Status: Offline Thanks Meter: 0 | What option should i use in IREB? Amd i tried the solution in that video. But once i enter in DFU, then use iTunes to restore the firmware(still original) i still get 1015. I just got the phone from someone, so i don't know if it was jailbroken before, maybe that could be my problem? |
02-15-2013, 14:13 | #6 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | Write original 4.1 firmware via DFU mode, then run Tinyumbrella and tick "exit recovery mode" . If this can't help rewrite 4.1 again and repeat the procedure |
02-15-2013, 14:39 | #9 (permalink) |
Member: 472557 Status: Offline Thanks Meter: 0 | Step 10. Browsing & select 4.1 firmware. -> STILL OFFICIAL FIRMWARE ? Do i still install Official firmware? Or i need custom at this stage? I am not sure how this works. I tried creating custom firmware using the latest version of redsn0w, but i got an error message saying it couldn't because of my operating system. I use win8 x64. |
02-15-2013, 15:50 | #10 (permalink) |
No Life Poster Join Date: Feb 2008 Location: ATI atheeq technical(srilanka)
Member: 709520 Status: Offline Thanks Meter: 275 | use ired to DFU mode then try gsmsandwich custom firmware 4.2.1. (no need to activate, jailbreak, unlock. ) if the phone baseband update to 6.15 also no error . tested two days before |
02-17-2013, 14:56 | #15 (permalink) |
Member: 472557 Status: Offline Thanks Meter: 0 | Ok. Sorry for the late reply. I honestly say i don't know exactly what made the problem go away. But here is what i did. I tried to restore again via iTunes, firmware 4.1. I got recovery mode. I used recboot to kick the phone out of recovery mode. I used redsn0w to put the phone in pwned DFU mode. Then i installed 4.1 firmware via redsn0w(only install cidya). Got emergency call. Instaleed firmware again using change baseband as well. Job well done. Just like in the initial instructions. What was odd for me, is that sometimes i could not open the phone, and itunes would not detect it. But after a good 6 hours of sleep, it recognized it and i was able to follow the initial instructions. Now there is one more thing, that i would like to know. After the firmware update, it doesn't move like before. there is a slight delay in response and i guess it's due to the fact that i am using firmware 4.1, and the hardware is not fully ready for this firmware. Is there any way to fix this delay?. By delay i mean the fact that when i open an app, it takes longer to open. Or the keyboard has a delay between the time i press the button and the time i hear the click sound/letter appears on the screen. |
