Error tying to install ultrasn0w? Not working for me, updated 3g 3gb to OS4, jail broke it, but when i try to install ultra snow i get this error NOTE:- The requested modifications cannot be applied due to required dependencies or conflicts that cannot be automatically found or fixed . Does anyone know what this is, and how to fix it? i have restored the iphone twice now and jailbroken, but still the same error? |
reload fw 3.1.3 and then it will work These are instructions on how to unlock the iPhone 3G and iPhone 3GS for use with any GSM cellphone carrier using UltraSn0w. This will work with the iOS 4.0 firmware. view this website iClarified - iPhone - How to Unlock the iPhone 3G, 3GS Using UltraSn0w Before you can follow these instructions you must have a jailbroken iPhone and you must be on the 04.26.08, 05.11.07, 05.12.01, or 05.13.04 baseband(modem firmware). |
Thought we couldnt downgrade iphones now? |
br |
Can you explain more plz? how do you add these? |
1 Attachment(s) |
SS |
Jbreak your phone,start cydia. Connect ur phone to pc Start cyder,in tab sources add (if not already there) www.repo666.ultrasn0w.com/Packages Hit start Hit Put Sources to Cydia Go to tab Packages and u will see ultrasn0w 093 there. Right click on it and Download with dependencies (if possible,if not,use posted mobilesubstrate) Check in cyder subfolder archives that u have ultrasn0w.deb and mobilesubstrate_0.9.3087-1_iphoneos-arm.deb Go to tab File manager and in cydia chace u should have these files Hit Cydia Autoinstall Drag&drop those 2 files from left to right window. Restart ur phone,done! regards |
the same problem.... i have the same problem... with cydia.. i downloaded cyder.... but i can„t seem to find my way around it.. i need some help... i can„t make my iphone workable.. i have no ideea whatsoever.. please help me.... i have 3 g , and someone upgraded it to 4 but it worked too slow. i downgraded it to 3.1.3.. and i jailbroke it with spirit.. it works.. only that i can„t make it recognize the sim... what to do????? |
I fixed this issue a different way, I has 4.1 and installed cydia, seems like the problem is when it installs the repo by itself, what I did is I deleted the www.repo666.ultrasn0w.com/ repo and added it again, and it worked this time hope this helps guys |
