Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 02-22-2009, 00:17   #151 (permalink)
Member: 977901
Thanks Meter: 12
@GS_guy
i don't know if it makes sence to replace the configfiles aftere MuscleNerds explanation.
@nass83
I think they mean mobile terminal. Guess you know whats a terminal.
@MuscleNerd
many thanks, that destroyed my hope, but as i've mentioned I already thought that they check the version.
So this could be an approach.
Don't know, how to find the hole to access the cpu,
but maybe it would be easier to manipulate the new baseband file!
" IS THE VERSION YOU SENT ME LESS THAN THE VERSION I'M RUNNING?"
So, we have to give the old 02.28.00 baseband the identity of the
new 02.30.03 firmware!?!
If i understand you right, the CommCenter arrange the communication between the baseband and the modem?
So which procedure is asking for the version of the baseband?
The CommCenter? no?
It has to be the Updater? (the apple updater)
I mean, if you had 02.28.00 on your phone and done the upgrade to 02.30.00 apple has to put the new version for the baseband on the phone?
It is not a hardware solution.
I think there are three posible ways:
1.) The one MuscleNerd told about, which means a enormous knowledge of system programming.
2.) The manipulation of the application that updates the baseband
3.) Or the direct manipulation of the new baseband,
to make the asking for the version answering with yes.
I don't know, if the baseband file i have realy the original baseband file, so is there a possibility to read out the baseband version?
I have a 02.28.00 running on an other phone.
Old 02-22-2009, 00:23   #152 (permalink)
Member: 977901
Thanks Meter: 12
sorry i've forgotten to ask.
I've heard there are two cpu's, one for the bootloader and one for the baseband?
And i didn't downloaded and installed the var files (mentioned in the tuto) because they want me to put it under the path .../audio
And i don't need any kind of file in the directory /audio to manipulate the baseband.
Old 02-22-2009, 00:47   #153 (permalink)
Member: 578886
Thanks Meter: 78
That's exactly my point, and that's why it's easy to see this for the prank that it is. If you open up those files with VLC or some other player, you'll see they are a woman saying the digits 0-9,#,* in an erotic manner, as though she's about to orgasm.
A woman's orgasm doesn't trick the baseband into downgrading itself.
The only other files in their "solution" besides the woman orgasms are the stock Apple BBUpdaterExtreme and baseband files, which follow the rules I described above.
Notice that their own video shows them at baseband 02.30 after their "solution" is run.
Old 02-22-2009, 00:52   #154 (permalink)
Member: 578886
Thanks Meter: 78
So, we have to give the old 02.28.00 baseband the identity of the new 02.30.03 firmware!?!
Yes, but that can't be done because the identity of any given firmware is embedded within it, and is protected crypotgraphically by a signed hash. Modifying the identity inside the image ruins the hash, and causes it to be rejected.
The CommCenter? no?
CommCenter does not participate in the BB programming step. You ask it to get out of your way so that you can run BBUpdaterExtreme.
Right, Apple just invokes BBUpdaterExtreme using the newer firmware files. The baseband will accept them since their version # is greater than its own.
Either scroll to the bottom of Settings->General->About, or launch minicom using /dev/tty.debug and issue the "AT+XGENDATA" command.
Old 02-22-2009, 02:49   #155 (permalink)
Member: 594693
Thanks Meter: 10
guys please give me original key sound files to Iphone)))
I am LOL))))
Old 02-22-2009, 06:34   #156 (permalink)
Member: 447548
Thanks Meter: 83
yeah did it!! got names noticed by posting FAKE and then got GOOD members banned and original programmers name dragged in mud..
yeah did it too. jeerked off to erotic sound files
The Following User Says Thank You to platinumLA For This Useful Post:
Old 02-22-2009, 09:11   #157 (permalink)
dharmdev's Avatar
Member: 51125
Thanks Meter: 1,435
Originally Posted by UnLoCkit View Post
Finally we did the IPHONE 3g 2.2.1/2.30 Tsamba method
How to work with Iphone 3G 2.2.1/2.30 modem
Do this at your own risk.
must haves:
1. wireless router connection
2. WINSCP
3. Toggle ssh, mobileterminator, automatic ssh (available from cydia via wifi)
howto:
1. Downgrade your 2.2.1 Iphone to 2.2, during downgrading some error will occur---that's ok
2. Do quickPwn2.2 procedures (U must know it by now, else, start from reading howto unlock/jailbreak the Iphone thru quickpwn)phone is in DFU btw.
3. unlock using yellowsnow.
4. install automatic ssh then Toggle ssh
5. Now install WINscp to your PC and mobileterminator
6. Open and ENABLE Toggle ssh
HOST NAME: your Iphone's IP
USER NAME: root
PASSWORD: alpine
7. Save and Close. Then Open again to login: password: alpine
8. Your on the Iphone's Root, we will now be copying the files (attached).
9. <root>/system/library/audio/uisounds copy paste this file...
10. then <root>/var/root/ this file...
11. after that go to system/liblary/launchDaemons/com.apple.commcenter.plist ( rigth click)
properties on the box Octal enter 755 then click OK
12. Turnoff Iphone. Exit Winscp
13. Open mobileterminator
14. type su
15. Password: alpine
16. ype: chmod 755 BBUpdaterExtreme
17. Type: ./BBUpdaterExtreme update -f ICE2_02.28.00.fls -e ICE2_02.28.00.eep
18. Restart the iPhone
19. Phone will power on after a loooong wait
20. Done. Drink your Beer!
Files here..
BASEBAND
VAR FILES
WINSCP
Again, Follow Instruction Carefully..
USE AT YOUR OWN RISK!!
watch..
http://www.youtube.com/watch?v=pDpEacbeXP8
Big Thank's to boyaxe and Tsambakol Team
100% FAKE TSAMBA method. Will leave your Iphone with NO NETWORK!!
100% TESTED - NOT WORKING!!
ITS FAKE. YOU HAVE BEEN WARNED
Old 02-22-2009, 11:49   #158 (permalink)
Member: 974254
were can i finde ( 13. Open mobileterminator) in the phon or in the computer ???????
Old 02-22-2009, 13:40   #159 (permalink)
Member: 977901
Thanks Meter: 12
@Nass83
You first have to jailbreak your phone to get cydia.
Then open cydia ->search >"mobileterminal" -> install.
You also need openssh to access your phone from your computer.
But pay attention, this is an ssh connection to your phone.
You should use this only, if you know what you are doing!
@maximbelov and platinumLA.
So you've really overidden your sound files???
But you just have to copy the var.rar file into you UISounds directory!
So with ssh you can remove the file. Not if you've overriden the whole directory!
OK. I copied it (UISounds) to my computer, but its a file with 2,2MB and i can't attache it. If you need it tell me. (or get it back by doing the Update with iTunes)
@MuscleNerd
sorry, i've tried to install minicom, but i have problems with setting it up.
Always, when i try to give the paths, i can't use the cursor.
It's always jump out and i haven't find a possibility to save my settings.
And i'm not sure, if i really deleted the firmware,if so, is it still possible to use AT commands to check the modem?
sorry for my stupid question, but does minicom communicates directly with the modem or with the firmware?
I thought, without firmware i can't connect to the modem???
I mean i send a command to the modem and the firmware on it is answering???
While googlin tonight, i found there is a cmd to set the firmware number.
So i would try to give the firmware the old (lower) number 02.28.00
and then i would try to flash the 02.28.00 by the apple Updater.
As i told, I'm not a hacker, but i would like to use my phone.
And i'm now very interested, because i saw there is a unix/linux OS running on the phone.
And i think now MuscleNerds way is the only way that gives us the possibility to access the modem firmware. By AT commands.
But first i have to know how to setup minicom and how to use it.
(last time i access a modem directly with AT commands is 3 years ago)
For all:
The procedure in this tuto makes my phone very insable!!!
It has no network!
It restarts every 3 minutes and i'm not sure if that stops after i put the new firmware on it. The only way would maybe to take the official update by itunes and then you're back on 02.30.00 firmware, hmm...
Thats not really a solution...but an approach...
The Following User Says Thank You to Geronino For This Useful Post:
Old 02-22-2009, 15:35   #160 (permalink)
Member: 978388
Now, I probably messed up. Cause:
The iPhone does recognize my simcard. Yet all i'm getting is a small vertical stripe and 3 dots (or little horizontal stripes ). It does'nt search for my carrier and flightmode does'nt help either, unless I depress it a 100 times. Then it searches for a minute or so and then says no service.
Any tips? I'll try again 2night, gotta go too work now.
Old 02-22-2009, 15:52   #161 (permalink)
Super Moderator
~Leo~'s Avatar
Member: 224065
Sonork: 100.1577902
Thanks Meter: 7,930
Iphone can't be unlocked CUZ YellowSnow CAN'T UNLOCK 2.30
Even who did this thread Is posting Fake solutions Or maybe copy &Paste without testing
NOT WORKING FAKE
If it's succefully Downgraded iphone should Preview Baseband version
Stop Spam :@
Old 02-22-2009, 15:55   #162 (permalink)
Super Moderator
~Leo~'s Avatar
Member: 224065
Sonork: 100.1577902
Thanks Meter: 7,930
Originally Posted by chealsea View Post
"TSAMBA" word extracted from TSAMBAKOL TEAM
" TSAMBA " Means " HIT OR MISS " ..malas mo lol ulol
if it doesnt work for you ..dont say its fake
maybe PURE LUCK doesnt sides you..but we do!!!
maybe you better try to get your eyes fix ..read first before anything else...
br
tsambakol team
maybe they should Write this thread right again
The LUCK SOLUTION IS HERE REFILL ur luck &Try it
Old 02-22-2009, 15:59   #163 (permalink)
Super Moderator
~Leo~'s Avatar
Member: 224065
Sonork: 100.1577902
Thanks Meter: 7,930
ok to end this sm 1 tried it &WORKED
POST complete screenshot for Phone with baseband version &Displayed full network in 1 Screen shot
Old 02-22-2009, 16:04   #164 (permalink)
Member: 978467
@MuscleNerd
When will the unlock be released by DEV TEAM for Baseband 2.30.03
Old 02-22-2009, 16:17   #165 (permalink)
Kanwalgee's Avatar
Member: 68392
Sonork: 100.100701
Thanks Meter: 658
Do all steps successfully but no signal.
Welcome india the great gpg tma+spy machine+polar box+unloc iphone 2.30.03 x-sim+pump chiragsp_codes Main Sales Section 0 04-24-2009 06:51
Page generated in 0.24993 seconds with 10 queries
