Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 07-27-2008, 15:26   #1 (permalink)
Member: 203576
Thanks Meter: 11
Unhappy [HELP] - Stuck in DFU mode Black screen
Another iPhone ... another problem....
NO history on the phone. Dont know what firmware or baseband it has.
The phone is stuck on a black screen and would not respond. When I connect the phone its not recognised.
Only gets detected by iTunes when I put it MYSELF in DFU mode (10sec Power&Home - 10sec Home)
I have tried restoring it to firmware: 1.1.1 , 1.1.4 and 2.0 - every time I get the SAME error 1601. I have not seen an Apple logo at all - only black screen.
Used iTunes 7.5, 7.6 and 7.7
iLiberty+, Ziphone, iDemocracy, iBricker nothing would recognise the phone.
Suggestions and help...
Jazz
Old 07-27-2008, 15:38   #2 (permalink)
malikkk's Avatar
Member: 141675
Thanks Meter: 7,641
Use Another Pc,laptop
And Try Tu Put In Restore Mode (home And Power Press 10 To 15 Second )
Post Results
Best Of Luck
Old 07-27-2008, 15:47   #3 (permalink)
Member: 203576
Thanks Meter: 11
tried a different PC and laptop... same thing... only recognised if i put it in DFU mode. will not go to RESTORE MODE.
Old 07-27-2008, 21:04   #4 (permalink)
Member: 31012
Thanks Meter: 6
Try use Apple Desktop or Laptop to do it, my iphone gots error 1604 in my PC, when i use my iBook, it work fine, no any error, good luck.
Old 07-27-2008, 22:16   #5 (permalink)
malikkk's Avatar
Member: 141675
Thanks Meter: 7,641
Originally Posted by ben5016 View Post
try Use Apple Desktop Or Laptop To Do It, My Iphone Gots Error 1604 In My Pc, When I Use My Ibook, It Work Fine, No Any Error, Good Luck.
No Need Apple Desktop
Try With Your Personal Computer {with Xp}
I Have Done It This Error Many Times Withoput Apple Desktop/laptop
Old 07-28-2008, 02:18   #6 (permalink)
Member: 715227
Sonork: 100.1577103
Thanks Meter: 144
Sure,but Mac Works Better
Have Downgraded/Flashed more then 1000 iPhones via Mac since 2007 , NO error in this time.... (sometimes 1015,but thats normaly)
Old 07-28-2008, 09:27   #7 (permalink)
malikkk's Avatar
Member: 141675
Thanks Meter: 7,641
Originally Posted by willmaster View Post
sure,but Mac Works Better
Have Downgraded/flashed More Then 1000 Iphones Via Mac Since 2007 , No Error In This Time.... (sometimes 1015,but Thats Normaly)
Flashed/unlock More Then 20,000 Iphones Via Xp
Without Problem
Old 07-28-2008, 15:04   #8 (permalink)
Member: 203576
Thanks Meter: 11
Very small progress...
The phone is now being detected by ZiPhone & iLberty - but ONLY in DFU mode. Still they CANNOT kick out of dfu mode!!!
iDemocracy & iBricker DO NOT detect the phone
Constantly trying to restore to 1.1.4 using iTunes 7.6 ... almost tried 20 times & still trying.
Old 07-28-2008, 15:16   #9 (permalink)
malikkk's Avatar
Member: 141675
Thanks Meter: 7,641
Completely remove iTunes and Apple Mobile Device support and then reinstall iTunes 7.5 or later
Old 07-28-2008, 22:52   #10 (permalink)
Member: 203576
Thanks Meter: 11
I uninstlled iTunes 7.6 - then deleted the file "iTunes Library.itl" - also deleted Apple Mobile Device support folder -
finally installed iTunes 7.5
iTunes 7.5 is not good
When I put the phone in DFU mode I hear the sound on windows but iTunes 7.5 does not show the phone in DFU mode. The restore screen in iTunes also does NOT show.
On ZiPhone ... when I try to put it to RECOVERY MODE the output log shows the following error: USBMuxListenerCreate: No error
Should I go back to iTunes 7.6 or do I need to delete any files? or make any other changes?
Old 07-28-2008, 23:07   #11 (permalink)
Super Moderator
~Leo~'s Avatar
Member: 224065
Sonork: 100.1577902
Thanks Meter: 7,930
man problem isn;t in itunes it's in drivers
http:///vbb/showthread.php?t=561652
check here it's only guide posted before
Old 07-28-2008, 23:10   #12 (permalink)
Super Moderator
~Leo~'s Avatar
Member: 224065
Sonork: 100.1577902
Thanks Meter: 7,930
man if u have any problem add me on ur msn &I will help u sounds seems this phone driving u crazy
The Following User Says Thank You to ~Leo~ For This Useful Post:
Old 07-29-2008, 00:13   #13 (permalink)
Member: 203576
Thanks Meter: 11
Thanks to AhmedLeopard... I got iTunes 7.5 working...and the Restore screen is back... will post further results as I continue my struggle with this unruly iPhone
Old 11-13-2008, 16:45   #14 (permalink)
Member: 465573
SAme problem encountered with my iphone.
Hi jajukhan
have u been able to get out of this damed DFU mode?
i'm having the same problem here. I got ver 2.0.2 winpwned on my iphone but when i tried to upgrade to ver 2.1 it got stuck in the 'recovery mode' [usb cable n itunes + cd picture]. However, my iphone is no more recognisable! i tried itunes, ziphone but no success...
Pressing sleep/home button, i can enter the DFU mode [black screen] but now ziphone sees my iphone but cant do any magic either since it tells me to restore via itunes. but the latter refuses to detect it!
can someone help :s
Old 11-13-2008, 19:25   #15 (permalink)
shedeed's Avatar
Member: 527884
Sonork: 100.1583794
Thanks Meter: 850
Remove U Itunes And Install It Again Then Put U Phone In D.F.U Mode
Then Try To Restore U Phone
Regards
Iphone 3Gs in DFU mode , how can exit dfu mode ? dieuphong2003 iPhone 2 / iPhone 3G / iPhone 3GS 37 06-23-2011 13:58
iPod touch 3.1.2 stuck in DFU mode HELP beerfoote1 iPhone 2 / iPhone 3G / iPhone 3GS 2 03-19-2010 15:07
iphone 3gs stuck on dfu mode... SicilianBoy iPhone 2 / iPhone 3G / iPhone 3GS 10 03-10-2010 12:06
Stuck in DFU mode ][No_WaY Bluetooth-Software 11 03-30-2006 00:40
Stuck in DFU mode. Upgrade failed a27 Bluetooth-Software 2 01-04-2006 19:19
Page generated in 0.27946 seconds with 10 queries
