Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 08-15-2008, 07:52   #1 (permalink)
Member: 537872
How to customzie, make and put ringtone on iPhone without iTunes
iPhone is so powerful and popular, but the pity is that it do not support ringtone customization, users can not convert audio to iPhone ringtone but have to buy ringtone from iTunes store. Fortunately I found an easy approach to customize iPhone ringtone and sync ringtone to iPhone without iTunes for free, here is the step by step guide:
You can also click the original iPhone ringtone guide to learn it intuitively
The tools you need are ********* iPhone Converter Suite and iPhone PC Suite(free), download links are as following:
********* iPhone Converter Suite:
http://download.*********.com/aimer-iphone-suite.exe
iPhone PC Suite (Totally free)
http://www.free-codecs.com/download_soft.php?d=4603&s=756
Note: iPhone PC Suite has to run under Microsoft .NET Framework, you can download it from:
http://www.microsoft.com/downloads/details.aspx?FamilyID=333325fd-ae52-4e35-b531-508d977d32a6&DisplayLang=en
iPhone PC Suite is a totally free green software, but ********* iPhone Converter Suite cost $39, while the publisher is now holding buy 1 get one free campaign and you can own it with $29 till Aug, 31th. I think it worth the money as buying ringtones costs more and even can not get your favorite ones.
The iPhone ringtone guide is composed of 3 parts:
1 How to extract audio to ringtone from DVD?
2 How convert audio and video to iPhone ringtone?
3 How to sync ringtone to iPhone without iTunes
Part 1 How to extract audio to iPhone ringtone from DVD?
1. Install ********* iPhone Converter Suite and run it. For Windows Vista user, you may have to run this program as Administrator, right click the program shortcut and click “Run as Administrator”.
2. Run the DVD to iPhone Converter, load your DVD by clicking “Load DVD” button, you also can load IFO file from your hard drive by clicking “Load File” button.
3 Click drop down list and select iPhone supported format (AAC, MP3, WAV, etc.) you want:
You can also customize the sample rate, bit rate and other parameters of your iPhone ringtone by click “setting”
To extract a clip from DVD to iPhone ringtone, you can click button “trim”, set the start time and end time.
Then click “Start” to extract iPhone ringtone from you DVD, Done.
2 How to convert audio and video to iPhone ringtone?
Start ********* iPhone Video Converter, then click “Add” button to load video file which you want to extract iPhone ringtone from(You can also load audio file to convert music to iPhone ringtone).
The operation is similar as extracting iPhone audio from DVD with DVD to iPhone Converter, set sample rate, bit rate and other parameters of your iPhone ringtone by click “setting”
Most users’ iPhone ringtone are always short, so you may want to convert a clip from movie to set as ringtone. Click button “trim” to set the start and end point of your iPhone ringtone.
Then click “Start” to convert a clip to iPhone ringtone from you movies or songs.
How to sync ringtone to iPhone without iTunes?
There are also some other ways to convert audio to iPhone ringtone and sync it to iPhone with iTunes, but I think these are a little complicated and users may be at a loss with such ways.
Here I recommend iPhone PC Suite, an almighty iPhone manager that can let you manage phone book, software, media and other files between iPhone and computer without iTunes easily.
But before use this tool, make sure your iTunes installed and has been connected with iPhone once before (Then you will never need not run iTunes when you use iPhone PC Suite to manage your iPhone).And when the first time you connecting iPhone, it will install PhoneDaemon on your iPhone, don’t worry it is green software and will do nothing harm.
The default language of iPhone PC Suite is Chinese simplified. To change it, find the folder” LangPack” under the extracted folder, delete “zh-CN.lang” and “zh-TW.lang”. (There is still Chinese when initializing, but after that it will be fine).
Now it will show you how to sync the converted iPhone ringtone to iPhone without iTunes.
Connect you iPhone to computer, double click” iPhone PC Suite” to start iPhone PC Suite, the program will scan you iPhone automatically for a short while. Then click button “Personal” on the main menu, select ”ringtone”.
Click “New Ringtone” to locate the converted iPhone ringtone,
Select your target iPhone ringtone, then it will upload the ringtone to iPhone automatically.
You can also manage your ringtone with it, like rename, delete, export. iPhone will sync with it automatically.
Then you can select your favorite audio file and set it as your iPhone ringtone on iPhone. Click “setting”->”Sound”->”Ringtone”, the converted ringtone is listed on column “Customize”. Now you can enjoy the fun of your unique iPhone ringtone!
This free iPhone PC Suite also has other powerful functions, we will share them later.
How to upload games and ring tones on DCT4 phones with UFS2 Tornado? drnele UFS2 + UFS3-Tornadoflasher 3 01-20-2011 07:06
how to install and wich is the best soft to record video and create ringtone in iphon svchost iOS Application, games & media area 0 12-10-2009 10:16
How to Run .jad and .jar files on LG KG200? umarriaz2k7 LG 0 02-26-2007 09:56
:-( How To Set Mp3 As A ringtone On 6600? ankit_jain Nokia Base Band 5 ( BB-5 ) 3 11-29-2006 13:39
Page generated in 0.25345 seconds with 8 queries
