03-29-2010, 08:33 | #1 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1269875 Status: Offline Thanks Meter: 0 | Is a DC Power Supply useful for repairs on an iPhone? |
03-29-2010, 15:32 | #2 (permalink) |
Member: 1265417 Status: Offline Thanks Meter: 0 | I have 4 in a row that I use to replace the power supply on most domestic equipment when I am mending it. Probably the most important thing it does is allow you to check the current that is being drawn. It's a lot of hastle to use it for an iphone though. One thing you absolutely need it for is to charge the battery because the iphone will not charge it's own battery once the battery is close to empty, there isn't enough power to run the charging circuitry so you have to remove the battery and charge it directly to bump start it. DON'T TRY THAT IF YOU DON'T KNOW WHAT YOU ARE DOING. |
Convert a DC Power Supply to A dc charger for cellphone battery | alayne | Hardware Equipments for GSM | 8 | 12-29-2008 11:24 |
1100 switching on only with DC power supply | yandbass | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 02-05-2005 21:49 |
Help Plssssss. 1100 Switching On Only With Dc Power Supply Unit | yandbass | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 02-02-2005 13:10 |
DC Power supply | Bypx | Smart-Clip | 6 | 01-11-2005 09:58 |
DC Power Supply | Farmer.PT | Hardware Equipments for GSM | 2 | 10-24-2002 12:23 |
