![]() | #1 (permalink) |
Junior Member ![]() Join Date: May 2015
Member: 2395711 Status: Offline Thanks Meter: 1 | ![]() Whatsapp accidentally uninstalled my first day! ![]() I have got 'install0s 2.5.2' to install ipa directly...shows 'invalid ipa' error. I have doubt i have wrong ipa. I have also tried other versions of whatsapp. Pls suggest me which version of 'whasapp ipa' is compatible with this model? or problem is with install0us? Pls suggest me solution, provide me compatible ipa. 'PLS BYPASS iTUNES' |
![]() | #3 (permalink) |
Member: 2395711 Status: Offline Thanks Meter: 1 | I dont want to use app store or itune....as i think they are asking Apple id. Whatsapp was already installed when i purchased phone from seller. But i deleted the app by mistake when i was arranging the icons...u know there is a minus badge appears? It deletes app :X i will be appreciated if anybody tell me the compatible version for ios 6.1.6 iphone. I will get the particular version from 4shared or mediafire! |
![]() | #7 (permalink) | |
Cheater -Don't Deal with him- ![]() ![]() ![]() ![]() Join Date: Feb 2015 Location: INDIA. JAI HIND
Member: 2353263 Status: Offline Sonork: +919836422676 Thanks Meter: 28 ![]() | whatsaap issue Quote:
Download direct via itunes and install your phone | |
![]() | #8 (permalink) |
Member: 2395711 Status: Offline Thanks Meter: 1 | Done! Here is the process if useful for anyone. • Install itunes on pc (this is needed to run itool) • Download itools on pc (this will install everything in iphone from pc) • Get 3-4 versions of 'whatsapp' from anywhere (yes! you can try 4shared . c o m ) • Install 'whatspad' from cydia Connect your iphone and run itool on pc. Go to applications, browse your apps and install. Finished! It may ask for Apple id on first run. If whatsapp is still not working...install-reinstall, reboot. Install whatsapp first and then install whatspad....then change this sequence. It took 4-5 days for me to research all this. ![]() |
The Following User Says Thank You to Deep_ For This Useful Post: |
![]() | #9 (permalink) |
Member: 2395711 Status: Offline Thanks Meter: 1 | Now Whatsapp is expired. It is asking for update. My phone is JB, no updates available. remove-install-reinstall tired many time. Looking for newer version. I think no one is working for older iPhones. Sad ![]() |
![]() | #10 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2008 Location: Philippines
Member: 805211 Status: Offline Sonork: 1661191 Thanks Meter: 68 ![]() | Quote:
The Following User Says Thank You to abe05 For This Useful Post: |
![]() | #11 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2011
Member: 1554684 Status: Offline Thanks Meter: 9 | whatsapp for older iphone models Quote:
1.install itunes on pc 2.download whatsapp 3.log in with the same id in your older 3g/3gs 4.now download whatsapp from app store. 5.done! | |
