Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 02-01-2011, 11:42   #16 (permalink)
nomangsm's Avatar
Member: 121662
Thanks Meter: 39
Originally Posted by mohseen View Post
Error 28
Hardware error. Return your device to Apple if possible. The problem is a bad dock connector on the iPhone. Must change the connector.
now still same after jack replace
Old 02-23-2011, 19:22   #17 (permalink)
Member: 625338
Thanks Meter: 19
Best solution
Originally Posted by turan alom View Post
change dock-connector-usb-charging-port after 28 error problem solved. 200% solution..
this is very good solution work perfect
Old 04-23-2011, 11:59   #18 (permalink)
hossnemamun's Avatar
Member: 324750
Sonork: 100.1590437
Thanks Meter: 302
dear Bro i face same problem. i remove Battery, wash full PCB, some hit under Lamp,
repair I/O Connector, Then Restore Firmware but error.
now i finding upgrade Firmware for my i phone 3G (8GB).
Model: M-A1241
FCC ID: BCGA1241
IC ID: 579C-A1241
any can help me.
Thanked
Hossne Mamun
Old 03-25-2012, 15:22   #19 (permalink)
Member: 386313
Thanks Meter: 5
error 28 solved with reheat the nand ic back of the sim holder
Old 04-02-2012, 16:56   #20 (permalink)
Member: 324750
Sonork: 100.1590437
Thanks Meter: 302
Thanks Bro,
i have same Error 28, wait i will try that then post result.
Thanks
Hossne Mamun
Old 04-02-2012, 17:40   #21 (permalink)
Shahin Hasan's Avatar
Member: 1529244
Sonork: 1720
Thanks Meter: 150
Originally Posted by nomangsm View Post
my phone stuck recovery mode when i try to kick revocery but still same when i connect itune flash it is error 28 show. if this hard ware error what i do my iphone is ok any one help me
Brother,
change back cover mien good shachi and then try to flash or exit recovery mode. I was face this problem and solved it.
Old 04-29-2012, 07:08   #22 (permalink)
Member: 1750907
Sonork: 3456547
hardware or software??
Old 04-29-2012, 18:48   #23 (permalink)
Member: 324750
Sonork: 100.1590437
Thanks Meter: 302
Dear Bro,
This issue is 90% Hardware Problem.
Thanks
Hossne Mamun
Old 01-03-2013, 12:57   #24 (permalink)
Member: 1854750
I changed battery and change dock connector but it still the same problem, what should i do bro.
Old 11-06-2013, 11:35   #25 (permalink)
Member: 1327068
Thanks Meter: 2
guys i solved this problem it's 1000000% hardware problem i just re hot nand chip and change usb pot of your pc hope its work
The Following User Says Thank You to hummadasif For This Useful Post:
Old 02-23-2017, 19:20   #26 (permalink)
Member: 2373448
Thanks Meter: 4
warming nand helps, i just restored my iphone 3gs after error 28!
bud its not permanent, how hot should i go and for how long?
Old 03-17-2017, 13:26   #27 (permalink)
Member: 2688186
use a battery with correct APN number and then it will work.
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 08-11-2006 15:29
Anything new on Nokia 5.28? mona Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 04-29-2000 08:04
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-20-1999 19:12
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.24852 seconds with 10 queries
