iPhone 3G 8GB Wont charge/sync/connect to any computer :( Damn.. I got a 3G 8gb here and i tryed everything! MY PROBLEM: The iPhone wont sync, charge or connect to any computers/macs with lots of differents USB cables.. I tryed: Changing battery, changing dock usb flex cable inside the phone... Also tryed to put the phone in DFU mode, but the computer wont find it^^ No charge at all... Still if i try to charge it from wall, or anything.. (The speaker and the mic on the flex cable is working ^^) |
Bump... :( No help? |
Try to clean the connector with toothbrush... Or restore iphone |
Make sure to use original cable only |
How would i be able to restore the phone when i cannot connect it to the computer.. I think the phone acutally CHARGES REALLY Slow and the phone doesnt give any sign, but the battery gets charged.. lol What can this be? :O |
Damn, this *****... Nobody able to help? :( |
I have the same problem now. Is there any trick for this problem? THX |
replay just change the charger conector ...... post results |
My iphone 3g hang up when it connects to pc. But it works fine sometime. I cleaned and changed usb port, usb cable, pc. No help. What to do now? |
maybe its grounded, try to clean the I/O connector.... |
Usb 3g 1 Attachment(s) You guys suck heres the solution |
Thanks man.. it worked for me... this solution solved my problem!!! Thanks!! p.s... before do the jumper.. just check if there's continuity or not between this 2 poins.. if there's no continuity make the jumpers and problem will solve!! |
I have the same problem with my 3G. Do I have to jumper the 2 points on the top-left side and the 2 points at the bottom-right side? thx in advance |
