Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 07-01-2009, 17:31   #1 (permalink)
Member: 1041121
Thanks Meter: 4
Exclamation iPhone 3G 8GB Wont charge/sync/connect to any computer :(
Damn..
I got a 3G 8gb here and i tryed everything!
MY PROBLEM:
The iPhone wont sync, charge or connect to any computers/macs with lots of differents USB cables..
I tryed:
Changing battery, changing dock usb flex cable inside the phone...
Also tryed to put the phone in DFU mode, but the computer wont find it^^
No charge at all... Still if i try to charge it from wall, or anything..
(The speaker and the mic on the flex cable is working ^^)
The Following User Says Thank You to Tori1234 For This Useful Post:
Old 07-02-2009, 13:31   #2 (permalink)
Member: 1041121
Thanks Meter: 4
Bump...
No help?
Old 07-02-2009, 14:22   #3 (permalink)
slososk's Avatar
Member: 447347
Thanks Meter: 4
Try to clean the connector with toothbrush...
Or restore iphone
The Following User Says Thank You to slososk For This Useful Post:
Old 07-02-2009, 14:30   #4 (permalink)
asiftele's Avatar
Member: 790515
Sonork: 100.1597362
Thanks Meter: 40
Make sure to use original cable only
The Following User Says Thank You to asiftele For This Useful Post:
Old 07-02-2009, 22:47   #5 (permalink)
Member: 1041121
Thanks Meter: 4
How would i be able to restore the phone when i cannot connect it to the computer..
I think the phone acutally CHARGES REALLY Slow and the phone doesnt give any sign, but the battery gets charged.. lol
What can this be? :O
Old 07-03-2009, 22:10   #6 (permalink)
Member: 1041121
Thanks Meter: 4
Damn, this *****... Nobody able to help?
Old 07-25-2009, 18:36   #7 (permalink)
recepoz's Avatar
Member: 167500
Thanks Meter: 16
I have the same problem now. Is there any trick for this problem?
THX
The Following User Says Thank You to recepoz For This Useful Post:
Old 07-30-2009, 06:51   #8 (permalink)
rogerboogie's Avatar
Member: 103024
Thanks Meter: 616
replay
just change the charger conector ......
post results
The Following User Says Thank You to rogerboogie For This Useful Post:
Old 08-05-2009, 17:21   #9 (permalink)
recepoz's Avatar
Member: 167500
Thanks Meter: 16
post results
Do you think did not I tryed it already? I also changed usb/charge chip but no change.
Old 08-06-2009, 00:50   #10 (permalink)
Member: 5792
My iphone 3g hang up when it connects to pc.
But it works fine sometime.
I cleaned and changed usb port, usb cable, pc. No help.
What to do now?
The Following User Says Thank You to xmans For This Useful Post:
Old 08-06-2009, 01:44   #11 (permalink)
EBRJO's Avatar
Member: 105175
Thanks Meter: 31
maybe its grounded, try to clean the I/O connector....
The Following User Says Thank You to EBRJO For This Useful Post:
Old 04-22-2010, 12:44   #12 (permalink)
Member: 462766
Thanks Meter: 4
Usb 3g
You guys suck heres the solution
The Following 2 Users Say Thank You to mahalcyprus For This Useful Post:
Old 04-27-2010, 17:47   #13 (permalink)
Member: 50700
Thanks Meter: 12
http://forum.gsmhosting.com/vbb/f456...4/#post5769958
The Following 3 Users Say Thank You to pinop For This Useful Post:
Old 05-12-2010, 14:17   #14 (permalink)
Member: 343635
Thanks Meter: 57
awesome!!!
Thanks man.. it worked for me... this solution solved my problem!!!
Thanks!!
p.s... before do the jumper.. just check if there's continuity or not between this 2 poins.. if there's no continuity make the jumpers and problem will solve!!
The Following User Says Thank You to DjDecibel For This Useful Post:
Old 09-07-2010, 10:16   #15 (permalink)
Member: 1388166
I have the same problem with my 3G.
Do I have to jumper the 2 points on the top-left side and the 2 points at the bottom-right side?
thx in advance
The Following User Says Thank You to BastiM For This Useful Post:
HELP, My twister wont connect to any nokia phones! tele f0n3 Twisterflasher 1 09-03-2006 06:14
Problem :- Cant connect to any LG.... :( Burnt Cobba VygisToolbox 9 12-02-2004 17:40
Page generated in 0.21237 seconds with 10 queries
