iPhone 3G Error 1016 Hi! I've an iPhone which always show error 1016 when restoring. If I try to restore to 3.0, error 1016. The same with 3.1.2. Also, If I start it with for example Blackra1n, the phone show the "no sim installed" message always(like a loop). Moreover, the baseband don't update. Is freezed in 2.28 version. ¿Any idea of the problem? I think that is for sure hardware problem but by the time I don't find the solution Regards and thanks! |
use your original cable, or try other USB port. |
what Version of iTunes you are using? and what flashfile you are using? pls attached picture of your iPhone it it is really a 3G!! |
use iTunes 9.0.2.25 new Version 100% work.......................... |
Tried other cable, error 1016. Tried that version of iTunes, error 1016. And it's a 3G, trust me. Regards |
Run ih8snow download link at end of post follow instructions at the top of the software and phone will restore no problem. http://www.sendspace.com/file/pzlseh BR MAttYB |
Spanish: Creo que eres Español. Esto tambien lo intenté en su momento y nada de nada. Esta todo lo que se puede hacer via software más que comprobado. Salu2 |
Use itune 9.0 or latest.......................... |
