01-10-2009, 23:48 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 42
Member: 178155 Status: Offline Thanks Meter: 15 | iphone 3g error 23 when upgeating now stuck on recovery mode |
01-11-2009, 14:03 | #3 (permalink) |
Member: 178155 Status: Offline Thanks Meter: 15 | a already try with itunes 8.0.2.20 and rest file iPhone1,2_2.2_5G77_Restore.ipsw and still this same error 23 in restore or DFU mode pls help to repair my iphon and what is error 23? |
04-22-2009, 09:39 | #10 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,172 | I have had one 2g whit same problem, the problem that i-phone ask always to connect whit i-tunes for recovery all restore file not need because the phone charge software but not able to install in itself, so using winpwn not help using i-liberty not help, phone is recognized only by i-tunes and ask always to restore.....at the end it's an hardware problem. |
06-02-2010, 21:47 | #11 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1316729 Status: Offline Thanks Meter: 0 | If it's a 3G and some others I found the solution in my case -------------------------------------------------------------------------------- My 3g Iphone would not come on unless plugged in to a computer and only gave the apple screen when it was. I was getting the code 23 in both recovery and DFU mode. I tried multiple computers and operating systems and still got the error. If i had thought about it unstead of being stressed I would have figured out the solution much faster. Code 23 is an error connecting to Itunes so the best way is to narrow down what coule be causing the problem. #1 Itunes corrupt software #2 Corrupt USB drivers or a bad usb port. #3 A bad Iphone usb cable #4 A bad data port on the IPhone the cable was connecting to (This was my problem). I also replaced the battery when I broke it down this far and I doubt this was part of the problem but, when I did replace it and the data port everything was fine again. I tried many different things and started to catch on when using iTunnel and winscp and it would lose connection. I wish you all the best of luck finding the answer to your problem and hope this helps someone else out there. |
06-03-2010, 10:07 | #12 (permalink) |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | solution solution about error 23 was posted long time ago please use search button and if you like just said thanks best regards br roger http://forum.gsmhosting.com/vbb/f456...utions-931272/ |
The Following 2 Users Say Thank You to rogerboogie For This Useful Post: |
iphone asks for drivers when i put it on recovery mode | 00aa | iPhone 4 / iPhone 4S | 11 | 07-22-2010 11:28 |
ipod 120GB stucked on recovery mode | Softway | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 12-05-2009 11:11 |
apple stuck on recovery mode | kulvindersingh | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 11-20-2008 08:11 |
16GB iPHONE stuck on recovery mode | ockiya | iPhone 2 / iPhone 3G / iPhone 3GS | 8 | 08-14-2008 06:38 |
stuck on recovery mode | matin78 | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 04-17-2008 18:14 |
