Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 07-08-2011, 07:42   #46 (permalink)
sdr
sdr's Avatar
Member: 25136
Sonork: 1591036
Thanks Meter: 54
Try this tutorial :
Error 1015 Fixer: Exit Recovery Mode In 1 Click ( Windows ) | FSMdotCOM
or this :
http://www.troublefixers.com/fix-itunes-error-1015/
Old 07-22-2011, 12:24   #47 (permalink)
shaikh_shoeb50's Avatar
Member: 1586370
Sonork: 100.1618206
Thanks Meter: 154
WOW !!! Work for me...!!! Thanx
Old 11-26-2011, 08:07   #48 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
I have same problam but dont,worry this is window issu bcuse i try 2nd system there no error so first install again windo and try again
Old 02-18-2012, 19:07   #49 (permalink)
Member: 475196
thanks so much it work for me
Old 03-15-2012, 19:08   #50 (permalink)
OLYMPIOS's Avatar
Member: 93568
Thanks Meter: 44
for me works when i ERASE the mac adress
127.0.0.1 localhost
74.208.10.249 gs.apple.com
from host file STRANGE ?
Old 03-16-2012, 08:20   #51 (permalink)
Member: 3658
Thanks Meter: 66
Just delete host file .
Old 09-26-2012, 13:10   #52 (permalink)
kharimobiles's Avatar
Member: 1814389
Sonork: 100.1621147
Thanks Meter: 30
but still sam problem any soulation ?
Old 09-26-2012, 16:45   #53 (permalink)
Registered User
Member: 194167
Thanks Meter: 2
thankuoooooooo free macth
Old 11-03-2012, 13:09   #54 (permalink)
hossnemamun's Avatar
Member: 324750
Sonork: 100.1590437
Thanks Meter: 302
Fix Error 3194 from iTunes during iPhone restore.
itunes error 3194 If you run into Error 3194 within iTunes when you are trying to restore your iPhone, iPad, or iPod touch, you can fix it by temporarily blocking Apple’s firmware signing services. Error 3194 seems to be triggered when unsigned firmware is used, often during an iOS downgrade or even during some restores. Here’s how to resolve the error:
Fix Error 3194
The fix is the same regardless of what operating system you are using:
Quit iTunes
Locate your hosts file, in Mac OS X this is /etc/hosts and in Windows this is c:\windows\system32\drivers\etc\hosts
Open the hosts file with Administrator privileges
Add the following lines to the very bottom of the hosts file:
74.208.105.171 gs.apple.com
Connect your iPhone to the computer
Launch iTunes........
now u can restore your iPhone.
Best Regards
Hossne Mamun.
Old 11-04-2012, 10:56   #55 (permalink)
C++
Crazy Poster
Member: 1832962
Thanks Meter: 7
IN CASE IPHONE 3GS DELETE HOSTS FILE ONLY
TESTED 100% WORKING
Old 01-07-2013, 10:31   #56 (permalink)
Member: 1828002
Thanks Meter: 2
I tried all methods, not work for me....can i get help where am i mistaking.....
Old 01-10-2013, 18:24   #57 (permalink)
rafikmob's Avatar
Member: 79627
Thanks Meter: 18
Red face i try all solution but don t worck
Fix Error 3194
Quit iTunes
Best Regards
Hossne Mamun.
please need help urgently
i have 3gs it stuck in dfu mode and when restore i have error 3194 or 1600 or the to error
need steps to restor this phone
The Following User Says Thank You to rafikmob For This Useful Post:
Old 01-16-2013, 09:20   #58 (permalink)
Member: 1677616
Thanks Meter: 6
i like
Originally Posted by yobb View Post
This iPhone 3G OS 4.0, when jailbreaked and unlocked resulting to NO SERVICE or no signal at all. Since I don't want to upgrade it to a newer firmware to avoid me using wifi, because this thing is not available!
So I'll restore this phone to repeat the process of jailbreak and unlock, but Sadly enough, for you guys who wanted to erase or restore your iPhone 3G into iOS 4 using iTunes 9.2 will be out of luck, since Apple is no longer signing the version 4.0 anymore. Instead if you insist on restoring your iPhone 3G into iOS 4.0 instead of 4.1, you’ll have error 3194 on iTunes.
[IMG]http://1.bp.********.com/_jzFOOHRsqBM/TJ2QotEE5VI/AAAAAAAAAxk/hd6_5peYQrQ/s400/error+3194+1.png[/IMG]
This is unfortunate, you can not upgrade your iPhone 3G officially, but.
You can still restore it unofficially.
Basically when iTunes showing “Verifying with Apple bla…”, that means iTunes is checking for signature from Apple’s signature server. And guess what, Apple no longer sign your iOS 4.0 firmware which makes your device is not eligible for restore, unless you update with iOS 4.0.1, this is one way for apple to force its customer to upgrade into the latest firmware, so all hacks will be eliminated if one is provided in Apple’s latest firmware version.
Now, we can bypass this signature checking when iTunes contacting Apple by changing the server from Apple’s Signature Server into Cydia’s clone of Apple Server.
Now here's the STEPS to be you to restore the same OS in your iPhone 3G!
It’s easy (for Windows):
1. Fired up your cmd.exe, and make sure you have administrator privileges.
2. Type this is: CD \WINDOWS\SYSTEM32\DRIVERS\ETC
3. Type this: edit hosts
4. Add this to the last line: 74.208.10.249 gs.apple.com
5. Restart your iTunes.
6. Put your iPhone 3G in recovery mode, by turn off the device first and pull the plug from your PC. Then press Home Button and connect your iPhone into your PC, then wait until the Recovery Icon shows up (iTunes icon with cable above it).
7. Now, restore your iPhone with your firmware iOS 4.0 (in windows using Shift + Restore, in mac using Options + Restore)
8. Voila, it will be restored succesfully, it’s fully working on my iPhone 3G.
You should notice the number 4 step is the bypass server, by pointing Apple Authentication domain into Cydia’s Server IP Address, this is trivial in unix, and thankfully, we can do this in Windows.
On Mac, it’s the same, except for the cmd.exe and the cd thing should be into /etc/hosts…
Enjoy your Jailbreak Restore…
Here are some screen cap while editing and restoring:
[IMG]http://1.bp.********.com/_jzFOOHRsqBM/TJ2SEinAbBI/AAAAAAAAAxo/V4wUmPhR4g4/s400/error+2.png[/IMG]
[IMG]http://1.bp.********.com/_jzFOOHRsqBM/TJ2TBCEjxxI/AAAAAAAAAxw/QQ2H5OFms6A/s320/error5.png[/IMG]
[IMG]http://1.bp.********.com/_jzFOOHRsqBM/TJ2Tv1moPnI/AAAAAAAAAx0/e0VXq0H35gQ/s320/error6.png[/IMG]
After those process, I use redsn0w_win_0.9.5b5-3, then the NO WIFI unlock for iOS 4.0 that can be search all over the net!
thanks its a good job
Old 01-25-2013, 12:27   #59 (permalink)
Member: 1873902
dear friends i m new in this forum idnt know how to use this forum i want help you guys that i have iphone 3gs and iwant to update this phone to ios 6.0.1 but here is a problem that when i click to shift + update it opens a window and i select a ios 6.0.1 aspw file .it starts but after extracting software it gives error of 3194.. does any one help me plzzzzzzzzzzzzzzzzzz i dont know how i see your reply can u plese help me via email my email id is [email protected]
Old 01-25-2013, 13:56   #60 (permalink)
pepe44's Avatar
Member: 922635
Sonork: pepe44
Thanks Meter: 23
ios 4.1 itunes 9.2 restore iphone 3g and 3gs no need shsh blog
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 08-11-2006 15:29
HEX for CLIP to restore Factory Defaults X-Shadow Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-28-2000 15:59
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-20-1999 19:12
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.28789 seconds with 9 queries
