Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 11-10-2009, 20:08   #1 (permalink)
naj
Member: 529141
Thanks Meter: 2
iphone 3g stuck in restore mode
iphone stuck in restore mode, about 25% left, what should i do, leave it or restart it, been stuck for 1hour now
Old 11-10-2009, 20:41   #2 (permalink)
shedeed's Avatar
Member: 527884
Sonork: 100.1583794
Thanks Meter: 841
Put U Iphone Into D.F.U Mode Then Restore It Phone Will Be Ok...
B.R
Old 11-10-2009, 20:51   #3 (permalink)
Member: 185352
Thanks Meter: 19
You can hold both Power and Home buttons for 15 seconds or leave it to empty the battery completely, then charge it to 100%
Old 11-10-2009, 20:51   #4 (permalink)
naj
Member: 529141
Thanks Meter: 2
B.R
hi, will this not damage the iphone, what should i do, just take off the wire, the problem i have is that i have got it into restore mode, the one with the apple logo and a bar under it, just 25% left, but has been stuck there for 2 hours now,
Old 11-10-2009, 21:20   #5 (permalink)
Member: 496243
Thanks Meter: 42
Arrow
Hi Bro, disconnect from PC and just force it turn off by holding down the power & home button for 8-10 second, you will see the iphone go off with a bright flash, release both button, wait couple minutes and connect the charger to it, it should be back normal.
BTW, how did you get stuck in this? were you try to restore or jailbreak? is it a 2G, 3G or 3Gs?
Regards
Old 11-10-2009, 21:27   #6 (permalink)
naj
Member: 529141
Thanks Meter: 2
Regards
was trying to restore with custom frimware, iphone is 3g
Old 11-10-2009, 21:28   #7 (permalink)
Member: 1158477
Sonork: postbit
Before you attempt to run black rain, if youre in Vista, right click on blackra1n.exe, click on Properties then the Compatibility tab and click on Windows XP SP2 (or 3) and check Run as Administrator. THEN run Blackra1n. If you get stuck in the recovery screen, hold the power and the home buttons together for 10 seconds until the phone reboots. It should take you to the home screen again.
iphone accessories
Old 11-10-2009, 21:30   #8 (permalink)
Member: 823568
Thanks Meter: 5
try via diff pc
-o-o-o-o-o-o-o-o-o
Old 11-10-2009, 21:32   #9 (permalink)
naj
Member: 529141
Thanks Meter: 2
iphone accessories
hi, i'm not stuck in recovery mode, but i'm stuck in restore mode
Old 11-11-2009, 06:04   #10 (permalink)
Member: 496243
Thanks Meter: 42
Arrow
Hey Bro, you don't have to use custom ipsw to restore, just connect to itune again and press restore, it will restore the original apple file, then run Blackra1n jailbreak> open blackra1n via Wifi> install Cydia & Snow, when finish reboot your iphone.
Regards
Old 11-11-2009, 14:45   #11 (permalink)
naj
Member: 529141
Thanks Meter: 2
I Just unplug USB wire now iPhone has black screen, reconnected to iTunes, it connects but has black screen and iTunes say iPhone is in recovery mode, I try to switch it on but no luck, only when I connect to iTunes it connects but has a black screen, tried restore with un-mod frimware but still the same, gets stuck with about 25% left
Old 11-11-2009, 23:51   #12 (permalink)
naj
Member: 529141
Thanks Meter: 2
iphone keeps getting stuck in verifying iphone restore part of the iphone restore
Old 11-12-2009, 05:25   #13 (permalink)
Member: 496243
Thanks Meter: 42
Arrow
What's the OS you have on your computer?
Regards
Old 11-12-2009, 09:37   #14 (permalink)
naj
Member: 529141
Thanks Meter: 2
Regards
i have windows xp installed on my pc
Old 11-12-2009, 20:57   #15 (permalink)
naj
Member: 529141
Thanks Meter: 2
have tried on laptop with vista, still get stuck
iphone 3g stuck in headphone mode acd2005 iPhone 2 / iPhone 3G / iPhone 3GS 11 09-18-2010 10:03
iphone 3Gs stuck in restore mode help plz quickgsm iPhone 2 / iPhone 3G / iPhone 3GS 23 03-20-2010 22:28
Iphone 16gig stuck in boot mode Kashif Khan iPhone 2 / iPhone 3G / iPhone 3GS 0 09-14-2009 14:47
iphone 3g stuck in recovery mode, error 23 when restoring ongcy87 iPhone 2 / iPhone 3G / iPhone 3GS 8 07-18-2009 07:35
iphone 3g stuck in boot logo BUZZING iPhone 2 / iPhone 3G / iPhone 3GS 4 03-01-2009 11:04
Page generated in 0.39952 seconds with 8 queries
