iphone 3gs 3.1 stuck at recovery mode !! hi friends i have iphone 3gs version 3.1 stuck on recovery mode after trying to jailbreak with red snow by customer he use fw 3.1.3 to jaiilbreak and phone version is 3.1 now what to do ? i try to use irep to exit recovery mode but no luck :( and try to flash it with these version (3.1.3) but verfication server not allow these any one could help me :) note : phone is mc (new bootroom) |
[QUOTE=ahmad yousif;6070429]hi friends i have iphone 3gs version 3.1 stuck on recovery mode after trying to jailbreak with red snow by customer he use fw 3.1.3 to jaiilbreak and phone version is 3.1 now what to do ? i try to use irep to exit recovery mode but no luck :( and try to flash it with these version (3.1.3) but verfication server not allow these any one could help me :) note : phone is mc (new bootroom)[/QUOT use recboot to take it out of recovery mode |
[QUOTE=kings121;6070475] Quote:
if you want power your iphon you can flash it with virsion 4 but he can t be unlocked only original carte sim whork omar |
[QUOTE=ahmad yousif;6070497][QUOTE=kings121;6070475] i try it man but not do anything :([/QUOT is the phone asking for activation?? |
phone just show usp cable & cd icon |
put phone in dfu mode, restore using itunes (hold shift and click restore) using downloaded 3.1.3. Then re jailbreak and unlock with ultrasnow. after restore make sure phone is activated before jailbreak and unlock |
1)restore iPhone1,1_3.1.3_7E18_Restore 2) when finish,open redsnow 9.4 and put ur iphone in DFU mode 3) redsnow(browse) choose iPhone1,2_3.1.2_7D11_Restore 4) press next ,choose only cydia in in redsnow icon and press next 5) now ur phone is jailbroken and flashed ,wait till it finish 6) u will see some changes inside iphone during this 7) after go to menu .go cydia>sourses> look for http://repo666.ultrasn0w.com>install it now ur phone is jailbreak and unlock Be sure to put it in DFU mode in order to do this correctly Salam |
but the itunes not accept any firmware give error when trying to flash with 3.1.3 and i dont want to upgrade to 4.0 cause no jailbreak & unlock to 3gs 4.0 |
I have had same problem 2 days before...When i was jailbreaking 3gs 3.1 with old bootrom.....I pressed "yes" instead of "no" when redsn0w confirming about old or new bootrom and phonne stuck in recovery mode....So what i did that i jailbreaked it again.....In your case this must b like this.... 1: Open red sn0w and select 3.1.2 2: Press next and if redsn0w confirming about bootrom then please press "Yes"(As its MC)... 3: Put a check on "Cydia" and press next and now follow instructions given by the redsn0w... 4: Redsn0w now jailbreaking your phone wait for the process to finish!And now your phone will be ok! Note: If phone stays in "Recovery Mode" even after this procedure then chose "No" instead of "yes" in step 2....Hopefully this will solve the problem! Good luck! |
all done :) thnx |
Similar problem... Use Redsn0w and it stalls waiting for a reboot... http://i70.photobucket.com/albums/i8...neF0recast.jpg I point it at the 3.1.2 file and it accepts that then seems to start the process, finishes stage1 then stage2 and sits there, waiting for the device to reboot. Would appreciate any help. TIA |
