Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2008 Location: amman
Member: 764174 Status: Offline Thanks Meter: 259 | iphone 3gs 3.1 stuck at recovery mode !! i have iphone 3gs version 3.1 stuck on recovery mode after trying to jailbreak with red snow by customer he use fw 3.1.3 to jaiilbreak and phone version is 3.1 now what to do ? i try to use irep to exit recovery mode but no luck ![]() and try to flash it with these version (3.1.3) but verfication server not allow these any one could help me ![]() note : phone is mc (new bootroom) |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005
Member: 117950 Status: Offline Thanks Meter: 139 | [QUOTE=ahmad yousif;6070429]hi friends i have iphone 3gs version 3.1 stuck on recovery mode after trying to jailbreak with red snow by customer he use fw 3.1.3 to jaiilbreak and phone version is 3.1 now what to do ? i try to use irep to exit recovery mode but no luck ![]() and try to flash it with these version (3.1.3) but verfication server not allow these any one could help me ![]() note : phone is mc (new bootroom)[/QUOT use recboot to take it out of recovery mode |
![]() | #3 (permalink) | |
Member: 764174 Status: Offline Thanks Meter: 259 | [QUOTE=kings121;6070475] Quote:
![]() | #7 (permalink) |
Crazy Poster ![]() ![]() ![]() Join Date: May 2006
Member: 275511 Status: Offline Thanks Meter: 3 | put phone in dfu mode, restore using itunes (hold shift and click restore) using downloaded 3.1.3. Then re jailbreak and unlock with ultrasnow. after restore make sure phone is activated before jailbreak and unlock |
![]() | #8 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2008
Member: 896307 Status: Offline Sonork: 0096 Thanks Meter: 230 | 1)restore iPhone1,1_3.1.3_7E18_Restore 2) when finish,open redsnow 9.4 and put ur iphone in DFU mode 3) redsnow(browse) choose iPhone1,2_3.1.2_7D11_Restore 4) press next ,choose only cydia in in redsnow icon and press next 5) now ur phone is jailbroken and flashed ,wait till it finish 6) u will see some changes inside iphone during this 7) after go to menu .go cydia>sourses> look for http://repo666.ultrasn0w.com>install it now ur phone is jailbreak and unlock Be sure to put it in DFU mode in order to do this correctly Salam |
![]() | #9 (permalink) | ||
Member: 764174 Status: Offline Thanks Meter: 259 | Quote:
but the itunes not accept any firmware give error when trying to flash with 3.1.3 and i dont want to upgrade to 4.0 cause no jailbreak & unlock to 3gs 4.0 | ||
![]() | #12 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2005 Location: Timeless zone! Age: 29
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 145 | I have had same problem 2 days before...When i was jailbreaking 3gs 3.1 with old bootrom.....I pressed "yes" instead of "no" when redsn0w confirming about old or new bootrom and phonne stuck in recovery mode....So what i did that i jailbreaked it again.....In your case this must b like this.... 1: Open red sn0w and select 3.1.2 2: Press next and if redsn0w confirming about bootrom then please press "Yes"(As its MC)... 3: Put a check on "Cydia" and press next and now follow instructions given by the redsn0w... 4: Redsn0w now jailbreaking your phone wait for the process to finish!And now your phone will be ok! Note: If phone stays in "Recovery Mode" even after this procedure then chose "No" instead of "yes" in step 2....Hopefully this will solve the problem! Good luck! |
The Following 2 Users Say Thank You to MUNEEB_AKHTAR_RAZA For This Useful Post: |
![]() | #13 (permalink) | |
all done ![]() thnx | |
![]() | #14 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Mar 2010 Location: Tauranga: New Zealand
Member: 1264076 Status: Offline Thanks Meter: 5 | Similar problem... Use Redsn0w and it stalls waiting for a reboot... ![]() I point it at the 3.1.2 file and it accepts that then seems to start the process, finishes stage1 then stage2 and sits there, waiting for the device to reboot. Would appreciate any help. TIA |
![]() | #15 (permalink) |
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 145 | You did it in a wrong way.....Blackrain is only for 3.1.2 not for 3.1.3...For this new version you need spirit!Now use "Spirit" and see what happen! |
The Following User Says Thank You to MUNEEB_AKHTAR_RAZA For This Useful Post: |
Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 30 | 02-24-2016 09:21 |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 03:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
