03-09-2014, 16:46 | #63 (permalink) | ||
Freak Poster Join Date: Jan 2009 Location: ibadan...
Member: 943462 Status: Offline Thanks Meter: 9 | solved... NOTE: Myself (Oluromeo) and/or Sheraz Raza are not responsible if you got your iPhone bricked or damaged... This tutorial is for educational purpose only. You Do This Absolutely AT YOUR OWN RISK. Thanks for understanding. ___________________________________________ Quote:
Everything working fine including network now. For those that is having issues with theirs still, well I guess you could try what I tried that worked for me... (it may work for you too). BUT KEEP IN MIND THAT MINE WAS ON OLD BASEBAND OF iPhone 3GS with iPad BaseBand 6.15.00 and iOS 6.1.6... ============ Now enough story... I did a FRESH iTunes restore for the phone and use redsn0w to downgrade ipad baseband from 6.15.00. then jailbreak normally and install ultrasn0w. Then everything works fine now plus the network... =========== You can do this, Quote:
NOTE: Myself (Oluromeo) and/or Sheraz Raza are not responsible if you got your iPhone bricked or damaged... This tutorial is for educational purpose only. You Do This Absolutely AT YOUR OWN RISK. Thanks for understanding. ___________________________________________ | ||
03-10-2014, 20:00 | #66 (permalink) | |
Junior Member Join Date: May 2006 Location: POLAND Age: 40
Member: 275993 Status: Offline Thanks Meter: 0 | Quote:
so i go to REDSNOW and again do JAILBREAK, but i untick only install ipad baseband. aafter this operation i have a signal on my 3gs. wifi and gps works, but have 6.15 firmware of modem. when i try downgrade the baseband modem, it's nothing do, but phone worked. | |
03-13-2014, 10:53 | #67 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1481927 Status: Offline Thanks Meter: 0 | works great on 3gs 6.1.6 new bootrom locked & unlock it with ipad baseband 6.15.00 with ultrasn0w 1.2.8 then downgrade baseband to 05.13.04 now i have an untethered jailbreak thank you very much |
03-20-2014, 08:38 | #68 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2151478 Status: Offline Thanks Meter: 0 | able to get it to work. iphone 3gs new boot rom. iphone was on 6.1.3, tethered. update with itunes to 6.1.6. lost network. followed instructions, but repeated 2.1 to 2.9 with 2.8 install cydia and downgrade from ipad baseband before proceeding with step 3. now working fine. but it did take 2 days to get it working by experimenting on the steps to take. thanks a lot |
03-24-2014, 05:15 | #70 (permalink) |
Insane Poster Join Date: Aug 2009
Member: 1090048 Status: Offline Sonork: dinidu Thanks Meter: 10 | If your Modem Firmware is 6.15 and still you didnt gt the signal.? only thing you have to change in this tutorial is (instead of install ipad baseband you should downgrade it when you are jailbreaking the iphone) Perform a Clean Restore , Then open redsnow and do the jailbreak (select install cydia and Downgrade from ipad baseband) after installing ultrasn0w reboot your idevice and make sure, DO ALL THE PROCESS WITHOUT SIM CARD INSERTED (with sim card didn't worked for me.) after rebooting your device insert your sim card. you will get signal! That worked for me! Worked on new bootrom 100% Working! **Do this at your own risk** |
03-31-2014, 11:17 | #71 (permalink) |
Freak Poster Join Date: Aug 2005 Location: India Age: 43
Member: 169384 Status: Offline Thanks Meter: 110 | after all steps if NO SERVICE * Restore again * do the steps again * don't install p0sixspwn first. first install ultrasnow 1.2.8 after u got Network install p0sixspwn (it means last step to install p0sixspwn) |
The Following User Says Thank You to gokul2005 For This Useful Post: |
04-07-2014, 16:23 | #75 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Paris,Serbia Age: 34
Member: 957371 Status: Offline Sonork: Non user Thanks Meter: 189 | Just unlock before install p0sixspwn and working like charm.... TESTED 1000000000% old and new boot rom Last edited by stevandnk@gma; 04-07-2014 at 16:24. Reason: , |
