04-10-2014, 22:45 | #1 (permalink) |
No Life Poster Join Date: Dec 2009
Member: 1174562 Status: Offline Sonork: 100.1654149 Thanks Meter: 2,095 | iPhone 3GS restore 6.1.6 error 1600 need help I also tried with ireb but it changes nothing Help me please thanks for your attention |
04-10-2014, 23:32 | #2 (permalink) | |
Super Moderator Join Date: May 1999 Location: Wien/Austria Age: 48
Member: 16 Status: Offline Sonork: 100.1652085 GSMWorld Thanks Meter: 1,743 | Quote:
If you are trying to restore your Jailbroken iPhone with iTunes and always get error 1600, just follow these steps and I'm sure ERROR 1600 will be No More! I was trying to restore my girlfriend's iPhone 3GS but kept getting this stupid error no matter what i did. The only work around it was doing exactly what is described in these steps. Hope this can help everyone that is facing the same problem i did. Step 1: Download the firmware (ipsw) corresponding to your iPhone Download Redsn0w Download TinyUmbrella Step 2: Open Redsn0w and under the option "Extras" Select "Custom IPSW" and open the IPSW file you just downloaded (this step removes Baseband update from the output IPSW file and its name will start with NO BB). =close Redsn0w= Step 3: Open Redsn0w again and go to "Extras", now you will select "SHSH blobs" and then "Stitch". Now select "IPSW" and get the ipsw file that you just removed the Baseband update (the NO BB IPSW). =close Redsn0w= Step 4: Open TinyUmbrella, select the option "Save SHSH" and press "Start TSS Server" Step 5: Put your iphone in DFU mode (you can use redsn0w to help you with this under "Extras" and by selecting "Pwned DFU" ) Step 6: Run iTunes (it will detect your device in recovery mode), hold shift and click restore. Now select the IPSW that you just stitched with Redsn0w (file name starts with a 13digit number followed by NO BB). You are done, your iPhone will restore and won't update the baseband so if you have a baseband unlock you can still use it.
__________________ Wbr GSMWorld | |
