Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 04-15-2013, 10:34   #1 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
iphone 3gs restore error (-1)
hi
i received iphone 3gs with no wifi no bt no imei .....according to the customer it is factry unlock ....i check its serial number its safe (green) try to update but at 80% get error (-1) now set is stuck on recovery mode
Old 04-15-2013, 11:12   #2 (permalink)
dust2dust's Avatar
Member: 1284799
Sonork: 100.1649097
Thanks Meter: 138
try to restore it with 4.1
after restoring you will receive an error message, just kick it on ireb
Old 04-15-2013, 11:38   #3 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
i did this but only 1015 error can be fixed au said .....i am facing error -1 when try to fix with ireb set restart and again in recory mode not run recory bar
Old 04-15-2013, 12:08   #4 (permalink)
Member: 1834434
Thanks Meter: 9
try with snowbreez custam file or .......... update with redsnow
Old 04-15-2013, 12:10   #5 (permalink)
GSM-DOCTOR's Avatar
Member: 604333
Sonork: 100.1590054
Thanks Meter: 1,845
sound like BASEBAND CHIP
but you can try a custom firmware with sn0wbreeze to preserve baseband
regards
GSM-DOCTOR
Old 04-15-2013, 12:12   #6 (permalink)
Member: 1834434
Thanks Meter: 9
Or Downgrad bassband if sam problm it is hardwear change basband chip it is possible
Old 04-15-2013, 12:32   #7 (permalink)
evolutions's Avatar
Member: 863844
Sonork: 100.1587943
Thanks Meter: 40
change your computer, put your phone in dfu mode and try 4.1 version, your phone will be alright. after that you can upgrade it back to normal.
Old 04-15-2013, 12:37   #8 (permalink)
sachinpatel's Avatar
Member: 1749874
Sonork: 100.1663210QQ:20249255921
Thanks Meter: 437
bettry change lardo bro...
Old 04-15-2013, 13:33   #9 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
regards
GSM-DOCTOR
after restore with 6.1.3 custom making with snowbreeze set is power on there is no imei bt is 000000000 set is searching and restart after a few sec .....wifi is ok now .......what should i do now?
Old 04-15-2013, 13:39   #10 (permalink)
sjd012's Avatar
Member: 1835240
Sonork: 100.1624260
Thanks Meter: 26
try create a custom firmware sir then try to restore it via itunes ....
Old 04-15-2013, 14:29   #11 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
try to read my post again ......there is no baseband/bt is 00 00 00 no imei
Old 04-23-2013, 02:53   #12 (permalink)
Member: 1864168
Sonork: 100.1623636
Baseband Chip Problem...
Old 04-23-2013, 03:44   #13 (permalink)
Member: 1683245
Sonork: 100.1668667
Thanks Meter: 23
gm sir
i also faced this problem but isolved it by coustem firmwere by using snow breeze
are will u plse try with red snow to restore ur iphone without itunes
Old 04-23-2013, 03:52   #14 (permalink)
Member: 1885839
Sonork: 100.1596918
Thanks Meter: 19
i think BASEBAND chip is damage.
i have this also....
Old 04-23-2013, 04:10   #15 (permalink)
kp mobiles's Avatar
Member: 1910352
Sonork: 100.1656010
Thanks Meter: 87
change baseband chips solve your problem......................
Page generated in 0.19990 seconds with 8 queries
