iphone 3gs searching Do you advice I upgrade the baseband of iphone 3gs that is showing searching after jailbroken and Ultrasnow was successfully run.?? Here is the phone details: Iphone 3gs 16gb Version 5.1.1 Modem Firmware 05.16.05 SHOULD I UPGRADE THE BASEBAND? |
http://forum.gsmhosting.com/vbb/f456...1-1-a-1500802/ http://forum.gsmhosting.com/vbb/f456...guide-1522635/ READ here Before Posting and check SN before upgrading |
If your iPhone is not unlocked then you have to downgrade to 6.15 bb and then to 5.13 and you should be able to use your iPhone as normal |
The modem Firmware is 05.16.05 do i need to put it on 5.13? |
If your iphone was manufactured BEFORE july 2011, you can try to update to ipad baseband, and then downgrade. If it was manufactured AFTER july 2011, do NOT touch the baseband without first checking that your baseband chip is compatible... you will end up with an expensive brick |
after go to cidya add sources Untitled Document and install utrasnow fixer for 5.1.1 and after ultrasnow Enjoy |
please reboot the device into normal operating mode, then perform a clean "slide to power off" then try redsnow again The above error came up in the process of upgrading the basseband to 06.15 with Redsnow redsn0w_win_0.9.15b1. is there any other Redsnow available? |
you can get serial number through Settings>general>about>serial number Answer for Quoted txt You have to restore firmware version again and then jailbreak+update BB It look like your phone is already jailbroken and while writing ipad BB code's are conflicting with each other. Thanks :) |
