02-05-2013, 21:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Romania / UK
Member: 1009354 Status: Offline Thanks Meter: 237 | Iphone 3gs unlocking 6.1 iso 2. Make sure you backup your phone to avoid losing ur data 3. Remove any lock code 4. Connect ur phone and run Evasi0n 5. Fallow the steps 6. After cydia is on your screen add repo666.ultrasn0w.com source 7. Then go on search and type ~ultrasn0w~ and run it 8. Job done ... u have an unlock and JB iphone 3gs 6.X About the frimware can be even ipad baseband or downgrade on 05.13.04 in both case working perfect (in case u have ipad baseband and after all this u have searching just reflash the ipad baseband and phone will be ok.) Solution 100% tested and working Good Luck Last edited by MarKus85; 02-05-2013 at 21:24. |
The Following 25 Users Say Thank You to MarKus85 For This Useful Post: |
02-05-2013, 23:15 | #3 (permalink) |
Insane Poster Join Date: Apr 2008 Location: UK
Member: 755273 Status: Offline Thanks Meter: 17 | just a heads up for anyone having difficulty using redsn0w after evais0n to select ipsw 6.1 select ios 6.0 instead and install/downgrade ipad baseband and then install ultrasn0w regards |
02-06-2013, 12:33 | #5 (permalink) |
Member: 1009354 Status: Offline Thanks Meter: 237 | any future problem regarding 6.1 unlocking post here i will do my best to help BR |
The Following User Says Thank You to MarKus85 For This Useful Post: |
02-06-2013, 12:39 | #6 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | I'M Already Passed This Method Yesterday Same Procedure Using By Me Working Perfect. Bro:-Palash Ahammad |
The Following 2 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
02-06-2013, 13:22 | #8 (permalink) |
Member: 1009354 Status: Offline Thanks Meter: 237 | Try this 1. If you have bb 06.15 and ios 6.X the phone without sim show searching 2. Open Redsn0w 3. Go to Extra 4. Select frimware 6.0 5. Go back and press jailbreak 6. Uncheck the ~install cydia~ and sellect only Downgrade BaseBand 7. After that do a normal restore whit itunes whit accepted sim inside and u are done. But if u upgrade on 6.1 just downgrade to 05.13.04 and u dont need the ipad baseband, but if u wish to have ipad baseband on ur phone make sure ur baseband can be upgrade to ipad baseband ( iphone checker ) Good luck |
The Following 5 Users Say Thank You to MarKus85 For This Useful Post: |
02-06-2013, 17:39 | #14 (permalink) | |
No Life Poster Join Date: Mar 2009
Member: 988667 Status: Offline Sonork: 1593975 Thanks Meter: 42 | Quote:
iPhone Made Year := 2010 SAFE TO FLASH IPADE BASEBAND AT CURRENT RECODE DATE..21/11/2011 THIS INFROMATION ONLY VALID FOR IPHONE 3G AND IPHONE 3GS... | |
The Following User Says Thank You to 786ali For This Useful Post: |
02-06-2013, 17:50 | #15 (permalink) | |
Member: 1009354 Status: Offline Thanks Meter: 237 | Quote:
or just backup your phone and restore on 6.1 and fallow the steps from this initial post u need 10 min to do all this .... | |
