Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 06-12-2014, 02:08   #1 (permalink)
Member: 1766158
Sonork: 1618330
Thanks Meter: 24
iphone 3gs updaetd to 6.1.6 cannot jb
Someone updated this 3gs to 6.1.6, I tried to jailbreak a couple of hours ago but didn't work,
I also tried using tiny umbrella and did not open on w8.1
I also tried shift restore on a sb ipsw but always gets the 3194 (I haven't modified my hosts file yet)
I also jb using redsn0w with procdures to direct it to 6.0 but didn't work.
The 3gs is a new bootrom btw.
Thanks.
br,
The Following User Says Thank You to chunkiebone For This Useful Post:
Old 06-12-2014, 02:19   #2 (permalink)
Member: 1372118
Thanks Meter: 139
try this bro
check your baseband if 06.15 try downgarde ipsw baseband and restore via itunes / redsnow
if this factory unlock try restore use redsnow and after that jailbreak with ios 6.0.0 and install p0inx to untethered
Old 06-12-2014, 03:09   #3 (permalink)
Member: 1766158
Sonork: 1618330
Thanks Meter: 24
no not fu, i rely on ultrasn0w for unlock. yes it's 6.15 but I tried a couple of times to downgrade but didn't downgrade. I also have jb it a couple of times, but when finished it's always not activated.
thanks.
br,
Old 06-12-2014, 04:06   #4 (permalink)
Member: 2097905
Thanks Meter: 33
thanks.
br,
bro try to downgrade ipsw..
4.1ipsw will do..
JB with downgraded baseband..
then restore it again 6.1.6 firmware...
JB with redsnow,,
POST RESULT..
Old 06-12-2014, 04:13   #5 (permalink)
Member: 1766158
Sonork: 1618330
Thanks Meter: 24
where do i restore it? itunes or rs? will try your advice mate.
Thanks
Old 06-12-2014, 04:15   #6 (permalink)
Member: 2097905
Thanks Meter: 33
Thanks
restore it with itunes..
>>>downgrade to 4.1(baseband downgrade)
>>>upgrade to 6.1.6 (update baseband)
>>>Jailbreak unlock
Old 06-12-2014, 04:59   #7 (permalink)
Member: 1766158
Sonork: 1618330
Thanks Meter: 24
done. just didn't activate. after activation through wifi all is ok.
please close. thanks. just followed these steps:
iphone 3gs 6.1.6 jailbreak unlock susesfull
3gs iPhone2,1_6.1.6_10B500_Restore untethered jailbreak & unlock
1) Restore your device with iPhone2,1_6.1.6_10B500
2) Jailbreak
2.1) Open redsn0w_win_0.9.15b3
2.2) Go to extra
2.3) Go to select ipsw
2.4) Select iPhone2,1_6.0_10A403_Restore
2.5) Back
2.6) Jailbreak
2.7) Next, follow the instructions to enter dfu mode
2.8) Check install cydia & install ipad baseband
2.9) Wait until jailbreak done
3) There will be no cydia in your device
3.1) Open redsn0w_win_0.9.15b3
3.2) Go to extra
3.3) Go to select ipsw
3.4) Select iPhone2,1_6.0_10A403_Restore
3.5) Go To Just boot
3.6) Follow the instructions to enter dfu mode
4) after device on u can see cydia
5) Open Cydia.
6) Click the "Changes" tab in the footer.
7) Press the "Refresh" button in the top left corner.
8) After "Reloading Data", perform a search for "p0sixspwn" (the O is a zero).
9) Tap Install.
10) After installing p0sixspwn your device is untethered
11) Install ultrasnow 1.2.8
1000% network done
The Following 2 Users Say Thank You to chunkiebone For This Useful Post:
Old 06-12-2014, 05:53   #8 (permalink)
Member: 545722
Sonork: 100.1619680
Thanks Meter: 322
Not working..........................
Old 06-12-2014, 06:41   #9 (permalink)
dvd_anwar's Avatar
Member: 896667
Sonork: 100.1586139
Thanks Meter: 1,596
again restore and try this solution 1000000000% working
Old 06-13-2014, 07:44   #10 (permalink)
Member: 92215
Thanks Meter: 35
Restore in iTunes to 6.1.6
Open redsn0w, select iOS 6.0
Jailbreak and check Install iPad baseband only -- wait til it finishes then close redsn0w
Open redsn0w again, select iOS 6.0
Jailbreak and check downgrade iPad baseband only (with 6.15 I get no service) -- wait til it finishes then close redsn0w
Jailbreak and check Install Cydia only -- wait til it finishes then close redsn0w
If errors occur with redsn0w, try restarting your PC.
After Jailbreak, connect to WiFi, Open Cydia, Go to changes then upgrade all.
After upgrade re-open cydia and search for p0sispwn to untether.
Search for ulrasn0w and restart your iPhone.
Old 06-21-2014, 18:34   #11 (permalink)
Member: 2117616
Sonork: 100.1652203
Thanks Meter: 71
http://forum.gsmhosting.com/vbb/f852/iphone-3gs-6-1-6-untethered-jailbreak-unlock-sus
http://forum.gsmhosting.com/vbb/f852...sfull-1782349/
Old 07-05-2014, 16:07   #12 (permalink)
Member: 727850
Sonork: 100.1625445
Thanks Meter: 3
jailbreak with 6.0 ipsw bro
Page generated in 0.17920 seconds with 9 queries
