12-26-2007, 16:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: In My CoMpaQ LaPtOP
Member: 249300 Status: Offline Sonork: 10101010 Thanks Meter: 569 | Please Connect To iTunes |
12-26-2007, 16:21 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | ok bro it is in recovery mode ì suggest u restore it with verison 1.1.2 and the see wich boot loader have and baseband BR, Tito Millo |
12-26-2007, 16:31 | #3 (permalink) |
Junior Member Join Date: Jun 2007
Member: 529124 Status: Offline Thanks Meter: 2 | hi try to use ibrickr_v0.91 to restore your iphone but you need to khnow the version and download the restore after use AppTappInstaller to downgrade your iphone Files needed during the entire process: (You are strongly advised to download and keep these ready) iBrickr v0.91 (the best Windows to iPhone file system software) Saviour Pack (pay your respects to the Saviour Pack) wiNstaller (Prerequisites: .NET Framework v2.0) AppTappInstaller anySIM-1.1p PACAY (aka ‘point and click activation with youtube’) iPhone v1.0.2 Restore firmware Start iTunes and plug in your iPhone which is running the 1.1.1 firmware. Hold down the Sleep and Home button for 10 seconds. Allow the phone to power off, but keep holding down the buttons. After 10 seconds, let go of the Sleep button, but keep the Home button pressed until iTunes sees your iPhone. The screen on your iPhone should be displaying nothing right now. OR Use iBrickr v0.91 to help you get into DFU mode and restore v1.0.2 iTunes will ask you if you want to restore. Hold down Option or Alt, I forget which (Shift if you are in Windows), and click restore. When iTunes asks you what file you would like to restore from, navigate to your folder where you've downloaded and saved v1.0.2. When it completes, you will get an error. The iPhone will display the yellow triangle on the screen. Leave iTunes open, and run AppTappInstaller and select firmware v1.0.2. This may give you an error, but you should see the "Activate iPhone" screen after. Close iTunes. Press CTRL + ALT + DELETE, find iTunesHelper.exe under processes and terminate it and run AppTapp again and select firmware v1.0.2 Go to the folder where you extracted PACAY and start “(CLICK HERE) activate.bat”. Follow the steps on your screen. When it asks to power the iPhone off and on again: Hold the power button on the phone, slide the red slider, wait about 15 seconds and power the phone on again. |
Iphone 2G Different SIM detected Please connect to itunes ERROR | kushstha | iPhone 2 / iPhone 3G / iPhone 3GS | 27 | 10-24-2010 18:33 |
Different sim detected please connect to Itunes ? | xmans | Rebel SIM Card | 3 | 04-13-2009 18:49 |
Iphone 3g disable..connects to itunes | damabib | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 10-23-2008 20:32 |
Jail broken iphone not connecting to itunes | tamz | iPhone 2 / iPhone 3G / iPhone 3GS | 6 | 10-18-2008 18:41 |
Iphone - yellow triangle - connect to itunes - help!! | Cals | iPhone 2 / iPhone 3G / iPhone 3GS | 11 | 02-17-2008 12:34 |
