Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 02-08-2008, 15:18   #1 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,046
Iphone Unlock Without Tp Or Turbo Sim Fully Tested Method.
Free Iphone Unlock Without Tp Without XSim Or Turbo Sim Or Opening Phone.
READ IPHONE F.A.Q HERE IF YOU NEVER DONE ANY IPHONE BEFORE.
First Check You Should Have Modem Version In Your Iphone 4.2.13g Or 4.3.13g.
If You Don't Have No Problem Use 1.1.2 Firmware And Update It With ITunes Link At Down.
If You Have Already 4.2.13g Modem Or Newer
Do This
PART 1 IF YOU HAVE FRESH IPHONE TO UNLOCK & JAILBREAK..
Restore 1.1.1 Firmware Via ITunes
Now Do Jail Break Via Classic Way Or My Modified Way.
Call On Phone *#301#
Now U See Calling Tune..
Use Delete Option And Clear All Number From Screen And Press 0
Now You Can Call It .
Now U Get Answer Option Press It
Press Hold
Now You See You Get Call Again Press Decline
Now U See You Can Go To Contact Option
At Bottom Thread Option
Press + Sing To Add
Go To Add Url
Type prefs: (Type Same As I Typed) Press Save Once Only
Go To Again Add Url
Type i.unlock.no (Type Same As I Typed) Press Save.
Now Press Save Again
You See noname Contact With 2 Url Now
Click On 1 Url prefs:
Now You Are In Setting.
Go To General
Click On Auto-Lock To Never
Go Back To Setting
Go To Wifi
Select Your Available Wifi
Press Home Button To Main Screen
Now You See Activation Screen Again.
Press 0 And Call It
You See Again You Got Call Accept It And Press Hold
You See Its Call You Decline It
Go To Contacts Again Now Click On 2 Link I.Unlock.No
Now You Get Web Click On First Tab To Jail Break
Wait 1minute Only Or More Depend On Your Inet Connection Speed.
You Will Again Go Main Activation Screen Again.
Don't Worry Its Normal
After 1 Or 3 Minutes You Will Be At Main Deskboard Without Activation..
Well You Done Hard Part..
This Is Jail Break Of 1.1.1 Hope You Guys Loved.
PART 1 FINISH
PART 2 YOU HAVE ALREADY JAIL BREAKED 1.1.1 OR 1.1.2 OR 1.1.3..
THIS IS MAIN PART OF UNLOCK NEW BASEBAND VERSION.
Now Use Ibrickr
Go To Applications.
Install It And Restart Many Time Its Ask.
Now Click On Pxl Install
And Select Bsdsubsystem-1.5.Pxl All Stuff At My Site Iphone Folder.
Its Take Some Time.
After It Install Mobileterminal-Svn206.Pxl All Stuff At My Site Iphone Folder
After Install Go Back
Go To Files In Ibrickr
Go To Folder Usr
Then
Go To Folder Bin
Upload All Files From gunlock.rar
Upload ICE04.02.13_G.fls
Now Back Again
Off And On Again.
Now You See Terminal Option At Your Deskboard.
Go To There
Type
cd /usr/Bin
After Typing Press Return
Now You Have To Type Service Unload Command Which You Have To Do Very Carefully If I Writed In Capslock You Have To Write In To. Don't Forget If In Small You Also Type In Small If Caplock You Also Type In Caplock.
launchctl unload -w /System/Library/LaunchDaemons/com.apple.CommCenter.plist
Ok Now Press Return
If You Get
Then You Typed Correct If You Get File Not Found Means U Typed Wrong.
Now Type
chmod +x gunlock
Press Return
chmod +x secpack
Press Return
Now Type Main Command To Unlock
gunlock secpack ICE04.02.13_G.fls
Now Phone Is Working Wait Till Process Fully Finish.
After Finish You Have To Load Service Which You Make Off
Now You Have To Type Service Load Command Which You Have To Do Very Carefully If I Writed In Capslock You Have To Write In To. Don't Forget If In Small You Also Type In Small If Caplock You Also Type In Caplock.
Bingo Part Is Finish Phone Is Unlocked But Still Some Stuff Is Rest To Make It Fully Working.
PART 2 IS FINISH FOR UNLOCK JAIL BREAKED 1.1.1 OR 1.1.2 OR 1.1.3..
PART 3 TO UPDATE UNLOCKED JAIL BREAKED 1.1.1 FIRMAWRE IPHONE TO LATEST.. WITHOUT LET HIM UPDATE PATCHED AND WORKING BASEBAND.
Go To Installer And Install Oktopre Update For 1.1.2
If You Forget To Install Oktopre You Have To Do All Again So Becareful
After Done Back From Installer
Connect Phone To ITunes And Press Shift UPDATE
And Its Ask For File
Select 1.1.2 File
And Let Him Update Firmware ...
Now We Back To Activation Screen And 1.1.2 Firmware.
Go To Folder 1.1.2 Jailbreak .. All Stuff At My Site At Iphone Folder
Open windows.bat
Now Press Jailbreak
Its Detect Phone And Do His Work
After Finish You Get Your Phone Restart Few Times
Wait Till Rebooting Is Finish.
Now You See Deskboard Is Open Activation Is Done..
Ok Now Connect To Wifi And Install Iworld To Fix Crash And Dialing Number
Start Iworld Select Your Country Let Him Restart..
Man Phone Is Working Check Without Turbo Or Xsim Or Any Paying ............
PART 3 IS FINISH FOR UPDATE UNLOCKED JAIL BREAKED 1.1.1 FIRMAWRE IPHONE TO LATEST.. WITHOUT LET HIM UPDATE PATCHED AND WORKING BASEBAND.
PART 4 FAST AND PRO METHOD.FOR UNLOCK NEW BOOTLOADER PHONES AND MODEMS.
Iphone With Jailbreaked Already.
GoTo System
Install Bsd Sub System.
Add Source To Installer.
i.unlock.no
GoTo Unlocking Tools
Install 1.1.2/1.1.3 OTB Unlock
Let Him Run To Do Your Job.
FINISH PHONE IS UNLOCKED
PART 4 FINISH
This is small tutorial I think with this you can unlock your Iphone without losing any single $$$..
MY WEB LINK
www.gsmchevli.com/support/
Iphone
Folder
if you get problem in download there is rar and zip file there. please download that.
Big Thanks goes to geohot Without Him No One Using This And Doing Iphone For Free
1.0.2: iPhone1,1_1.0.2_1C28_Restore.ipsw
1.1.1: iPhone1,1_1.1.1_3A109a_Restore.ipsw
1.1.2: iPhone1,1_1.1.2_3B48b_Restore.ipsw
Best regards,
Gopal Chevli.
Hope people love this.
The Following 15 Users Say Thank You to stanner_austin For This Useful Post:
Old 02-08-2008, 16:15   #2 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 574
thanks sir, naira here not rupees
Old 02-08-2008, 16:22   #3 (permalink)
mccm's Avatar
Member: 173565
Thanks Meter: 71
thanks ,best with relevent software download link .
Old 02-08-2008, 16:38   #4 (permalink)
Member: 195290
Thanks Meter: 7
where link to download all this files again?
regards
Old 02-08-2008, 17:02   #5 (permalink)
Member: 271980
Sonork: 100.1573370
Thanks Meter: 222
very Good News . Thanks
Kabo...............
Old 02-08-2008, 17:18   #6 (permalink)
mccm's Avatar
Member: 173565
Thanks Meter: 71
anyone know how to recover iphones with no wifi ,imei 0049 ,no ICCID ?
Old 02-08-2008, 18:05   #7 (permalink)
Member: 166506
Thanks Meter: 18
I NEED HELP PLEASE it all went goot untill(Now Click On Pxl Install
Its Take Some Time.
Go To Folder Usr
Then
Go To Folder Bin
Now Back Again
Off And On Again.
Go To There)
i cant found anything on my iphone deskboard can u assist please
tx
Old 02-08-2008, 18:23   #8 (permalink)
Member: 166506
Thanks Meter: 18
please not that on step(Now Click On Pxl Install
And Select Bsdsubsystem-1.5.Pxl)the phone dosent soft-restart
tx
Old 02-08-2008, 18:44   #9 (permalink)
dexter_mn's Avatar
Member: 311316
Thanks Meter: 41
how about 4.03.13 modem fw?
my iphone is BL=4.06 vers=1.1.1 modem=4.03.13
client updated into 1.1.3
what i should do
its not work it?
Old 02-08-2008, 19:01   #10 (permalink)
I_sumo's Avatar
Member: 38103
Sonork: 100.100782
Thanks Meter: 165
Little bit easier way !
BUT much easier.. add this desbloqueiobr.com.br/rep as source to a Jailbroken 113 and then run AutoGunlock. Do as directed.
This works with any version without downgrading. Easier to enjoy GeoHot's way.
Old 02-08-2008, 19:51   #11 (permalink)
Member: 50105
Thanks Meter: 8
thanks my brother
i make it with my iphone ver 1.1.3 OTB
and now it's ok
thanks again
Old 02-08-2008, 20:34   #12 (permalink)
webiso's Avatar
Member: 10580
Thanks Meter: 43
some file is not downloading your suuport site in iphone folder example this "ICE04.02.13_G.fls
Old 02-08-2008, 21:09   #13 (permalink)
Member: 21937
Thanks Meter: 279
hi
is this method for all bootloaders ? or only for 3.6
also , please fix pxl folder on your site , cant d/l any pxl file
thx
Old 02-08-2008, 22:05   #14 (permalink)
Member: 299330
Thanks Meter: 5
Good work mates!!! Its surely the benefit of research work. will try it and post here.
Old 02-09-2008, 00:11   #15 (permalink)
Member: 132496
Thanks Meter: 30
1.1.2 OTB OK!
week47!
thnx
Unlock NOKIA BB5 without TP, or opening the phone, or credits ... and many more. MANOLE Main Sales Section 0 05-13-2008 19:07
bb5 unlocker without tp working or not working omkarvitekar Nokia Base Band 5 ( BB-5 ) 4 03-13-2008 18:57
v360 in test mode permanent after unlock without TP crysst Smart-Clip 4 12-18-2006 14:04
Page generated in 0.52488 seconds with 8 queries
