01-26-2010, 22:21 | #1 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1219816 Status: Offline Thanks Meter: 0 | LCD Not Working After Replacing Glass After connecting everything the 1 2 and 3 parts (and trust me they are connected I've opened and closed it a million times trying to figure this out) and putting the screen back in place nothing comes up on the screen. I've tried several hard resets, restores in iTunes, and a DFU restore. The phone turns on I can hear it and it vibrates, but theres nothing on the screen. I don't know what else to try. I've read other posts with similar problems but none of the answers work. I've heard people say you need a new battery or to take the batter out and put it back in, but I don't want to mess with anything else if its not going to work. Anyone have any ideas or can confirm that the battery solution works? |
01-26-2010, 23:15 | #2 (permalink) | |
Insane Poster Join Date: Nov 2008
Member: 894580 Status: Offline Thanks Meter: 15 | Quote:
Try another lcd mate looks like the one you have inserted is not working. If it is picking up on itunes then you have no fault besides your display which means that is 100% LCD. | |
01-27-2010, 01:37 | #6 (permalink) |
Freak Poster Join Date: Mar 2005 Location: UK Age: 43
Member: 127240 Status: Offline Thanks Meter: 82 | No.You need new lcd and you be very careful. Do not bend the flex close by the lcd edge. You have to bend the lcd flex ONLY on two white lines marked on it. It is very easy to damaged the flex. |
01-30-2010, 20:16 | #9 (permalink) |
Member: 1211025 Status: Offline Thanks Meter: 0 | You might have damaged the connector cable # 3, or the LCD. You may buy an LCD & find that the LCD was good. You will just be wasting your time and money on parts. I would say, just go with professional repair. I have used www.CupertinoiPhone.com in the past & was extremely happy with the result. |
02-09-2010, 00:30 | #10 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Australia
Member: 44593 Status: Offline Thanks Meter: 7 | iphone no display Hi m8 I had the same problem but i'm sure that it's not the lcd fault bcoz i put it to an other iphone and it works perfect. the iphone which had a problem with no display still sync to itunes and connect to pc. so please tell me what is the exactly problem thanx and br |
02-09-2010, 01:34 | #12 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: SWEDEN-China-Thailand-Singapor
Member: 917893 Status: Offline Sonork: 100.1584763 Thanks Meter: 3,156 | Quote:
hahaha so trying to save your self 230 $ uve now f¤¤ked your iphone .. great job there buddy the solution is replace the LCD and check for anyother damages youve done to nearby electronics on the actual pcb. | |
Touchscreen not working after replacing display | Kais_Unlocker | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 04-24-2009 17:50 |
5500 Sport still not working after replacing LCD | woonuts | Nokia Hardware & Hardware Repair | 2 | 07-27-2008 23:34 |
k850 keypad still does not work after replacment | wreksta | Sony Ericsson Hardware Repair | 4 | 05-02-2008 12:35 |
5510 keys not working after replacing LCD | roughana | Nokia Hardware & Hardware Repair | 1 | 04-06-2004 07:27 |
M55 LCD not working after flashing | Donaldas | E-Gold Based Phones | 0 | 12-18-2003 11:11 |
