01-10-2010, 14:15 | #1 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1021299 Status: Offline Thanks Meter: 1 | Pls solve my Problem When I lock my phone,sometime show this message "the accessory is not made to work with iPhone" show. How can I solve this problem.Pls guide me. Thanks in advance. Regards S.Wilson |
01-10-2010, 14:36 | #2 (permalink) |
Major Poster Join Date: Jan 2010 Location: At the bottom of the Universe
Member: 1204494 Status: Offline Sonork: 3465 Thanks Meter: 2 | Well I know this is no useful for you but it's better to not lock then to not unlock. I'm sure in your city there's a mobile service.Let them take a look. |
01-11-2010, 00:10 | #9 (permalink) | |
Freak Poster Join Date: Apr 2007
Member: 496243 Status: Offline Thanks Meter: 42 | Quote:
The headphone jack, power button, ring/vibrate and volume all in one flex cable. but check the charging cable first make sure it's locked down at correct place on the board before you do anything. Also according to the screen shot, the error message about the accessory is not made for iphone, normally it's refereed to the charger that you use is after market piece or it has a bad port, try it with a original one, it should take care of the error message or the whole problem, my guess is the charger can't perform the charging need so the battery was never charged up to begin with, therefore all the problems were from a weak battery. Regards Last edited by dcg28052; 01-11-2010 at 00:20. | |
The Following User Says Thank You to dcg28052 For This Useful Post: |
01-11-2010, 00:24 | #10 (permalink) | |
Regards | |
Uploade File failed Pls Solv My Problem | delower10 | Board, Server and Login Problems/Support | 6 | 05-15-2010 08:04 |
pls solved my problem | hdeyda | Cruiser Suite | 4 | 03-24-2009 20:03 |
pls solve my problem | cellncare | BB5 RPL | 0 | 08-22-2008 14:10 |
Pls Supporters Solve My Problem | New Style | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 07-26-2008 03:41 |
pls all enter solve my problem | odayking | Sharp | 8 | 02-10-2007 13:25 |
