11-03-2014, 08:45 | #1 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2285619 Status: Offline Thanks Meter: 0 | Running BB 6.15 cant downgrade and no service |
11-04-2014, 10:35 | #2 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1418242 Status: Offline Thanks Meter: 49 | hy, itīs not so hard to fix this :-) first thing you have to do is to upgrade it to 6.1.6 if it isnīt on the phone anymore. after this, open redsn0w and point it to 6.0 firmware (extras -> select ipsw), then press back -> jailbreak, just select "downgrade from ipad baseband", nothing else should be selected now . after the process is completed, close redsn0w and launch it again. again point it to 6.0 firmware (extras -> select ipsw) then press back -> jailbreak and this time only select "install cydia" nothing else should be checked. after finishing this second step, again restart redsn0w point it to 6.0 and select "just boot" from the extras menu. then when the phone is started install p0sixpwn and ultrasn0w, restart your phone and your done :-) if this helped you then just press the thanks button |
