Solution for Iphone 3Gs No Network/No Service IF Your Iphone is 3Gs With OS 4.1 Base Band 05.14.02 Requirements: 1. 4.1 firmware. 2. Redsn0w 0.9.6b5 3. Ultrasnow6.15 4. iFunbox Step 1 1. Open Redsn0w 0.9.6b5. 2. Browsing & select 4.1 firmware 3. The new message box will pop up so click YES 4. Click next 5. Check on INSTALL CYDIA and INSTALL IPAD BASEBAND 6. Again new message box will pop up so click YES 7. Click next 8. Follow introduction for DFU 9. Jailbreak Done ! If you get no network Step 2 1. Open iFunbox.exe 2. click on "Rawfile system" 3. open VAR 4. open root 5. open media If it is empty..make new folder.named"Cydia" 6. open Cydia .. IN "cydia" folder make another folder named:AutoInstall" IN :AutoInstall" folder past ultrasn0w files(First extrac it then Past) REboot 2 time.. ENjoy Tested by ME 100% working... |
Ultrasnow6.15 u have other link for downloading r just attach here |
http://forum.gsmhosting.com/vbb/f456...guide-1151335/ |
How To Fix White Cydia Icon, Safari Crashes After This well, having 3gs... after jailbreak n updated baseband firmware... now i cant run cydia... even tried with ifunbox... restarted..10 times...still not unlocked... well as i got info.. tried with tethered... but still cant get sucsess......... |
100% soluton 100% solution 4 unlock sucsess |
@ MicrostarGSM® thanX Tested :) |
After installed ultrasn0w 1.2 network available for few minutes and then back to no service.... any one can help me for fix this problem |
1 Attachment(s) Quote:
Thanks,but.... Quote:
1. Open Redsn0w 0.9.6b5. 2. Browsing & select 4.1 firmware 3. The new message box will pop up so click YES 4. Click next 5. Check on INSTALL CYDIA 6. Click next 7. Follow introduction for DFU 8. Jailbreak Done ! Step 2 1. Open iFunbox.exe 2. click on "Rawfile system" 3. open VAR 4. open root 5. open media 6. open Cydia ..(If it is empty..make new folder.named"Cydia") IN "cydia" folder make another folder named:AutoInstall" IN :AutoInstall" folder past ultrasn0w files(First extrac it then Past) REboot 2 time.. ENjoy |
