10-07-2011, 21:13 | #1 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1198842 Status: Offline Thanks Meter: 162 | succfully repair 3GS brick baseband /Gray wifi-bt-IMEI with IOS5GM i used 1- windows xp pro sp3 uptodate 2- Install Itunes 10.5 beta 7 download 3- used IOS 5 IPSW 5 GM download ======================= process: 1- install custom IPSW 4.1 2- open itunes and make backup ( just to let Itunes creat Lib ) 3- press shift with restore ( normal mode not DFU or other mode) 4- iphone with finish restore,, before the end of it 70% itunes will show message up near the install process line ( restore iphone firmware.. ) this is good news that baseband rewritten all componnet) 5- after finish restore and restard the iphone,, itunes can not aktive it.. i just plug the iphone out and restart it too time manual and then plug it,, and opps... all da with baseband ( firmware 05.16.05 ) wifi and other all okay. well i didnt try to upgrade the bb to ibad,, as happy now can use it with original simcard which it will be unlocked from t-mobile for free Jan 2012 give try and dont forget the thanks buttom. |
The Following 17 Users Say Thank You to frake50 For This Useful Post: |
10-08-2011, 03:38 | #3 (permalink) |
Freak Poster Join Date: Oct 2007 Location: manila-kuwait ksa Age: 39
Member: 600970 Status: Offline Thanks Meter: 89 | testing mode... i have 3gs in my hand today..it is two days old and i try to downgrade to 4.1 to unlock and jailbreak..wen i finish no wifi no imei i hope this is the solution... thanks mate i post it what happen... |
10-08-2011, 15:45 | #7 (permalink) |
Member: 1198842 Status: Offline Thanks Meter: 162 | gadgets23: this way not for you, you have ibad baseband.. this try only to 3gs which didnt show firmware. and when restore with original ipsw, give no error. ( but didnt show firmware ) |
10-08-2011, 16:25 | #8 (permalink) |
Insane Poster Join Date: Jul 2004 Age: 53
Member: 73434 Status: Offline Thanks Meter: 2 | @frake50 yes so it seems is there a fix thats known about these newer type 3GS that seems to get bricked by the iPad BB6.15 ?? !! have tried sooo many things now needs some inspiration ! |
10-08-2011, 17:35 | #9 (permalink) |
Member: 1198842 Status: Offline Thanks Meter: 162 | your chance 1% of luck. follow this 1- put your idevice in DFU mode ( DFU mode screen stay black ) 2- run ireb-4 and choice 3gs, keep it on dfu mode 3- restore with shift and choice custom ipsw 4.1 ( your hosts keep it clean, so itunes will syns it from Apple server.. it will finish with out error 4- to active ur device replace lockdown. or use activieted custom ipsw 4.1 5- Important, because you are on ibadbaseband,, your chance only to rewrite ibad baseband again and again with redsn0w... hope it will write it,, if not,, then you have hardware problem with baseband. |
10-11-2011, 21:35 | #14 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Cracow
Member: 739941 Status: Offline Thanks Meter: 111 | Today i try this solution but nothink happend good. my iPhone still NO IMEI NO WIFI i think in my case i have got broken BB Memory so BaseBand Parts can not start. When i change memory fo another iphone worked propertly. Wifi is ok but IMEI its wrong. Any body know how flash BB Memory, how change IMEI on new memory ? |
10-12-2011, 03:44 | #15 (permalink) |
Freak Poster Join Date: May 2009 Location: lake lanao
Member: 1030567 Status: Offline Thanks Meter: 67 | any body test this sulotion plss post here tnx advance!! i have same problem before my 3gs 3.4.5 & baseband 5.16.2 after downgrade to 4.1 & jailbreak & update BB my baseband & wifi disable, but before i downgrade my 3gs is working nothing problem!! plss help me to solve this problem!! |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
