10-23-2017, 10:06 | #1 (permalink) |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,712 | How to download and install Android apps using the 1mobile Market on BlackBerry 10 We've been covering bits and pieces on how to download and install Android apps on BlackBerry 10 since the OS 10.2.1.1055 leak. While there are numerous ways to get this done including using the native File Manager or your Browser, perhaps one of the easiest ways is with the 1mobile Market. This third-party Android app store gives you access to hundreds of Android apps that may or may not be readily available on BlackBerry 10. Using the 1mobile Market to download and install Android apps on your BlackBerry 10 device is a very simple process, but in case you need some guidance, we've laid it all out here from start to finish. Note that this only works with the leaked OS 10.2.1.1055 for now (and most likely higher versions at some point). Keep reading to see how it's done. Download 1mobile MarketFirst things first - you'll need to download the 1mobile Market to your device. To do so, just point your BlackBerry browser to 1mobile.com/app/market Tap the For Phone button under download Choose the location to save the APK file and tap Save When the download is complete, tap the file to open the APK Tap Install, then tap Accept in the permissions popup When the install is done, tap Open Now the 1mobile Market is installed on your device and you can freely browse and install Android apps. How? Keep reading .... Downloading and Installing Android Apps Browse through the lists or search for an app you want to download Tap the app title to open the app page Tap Free to begin the download When the download is done, the native installer will start. Tap Install Tap Accept on the permissions popup When the install is done, tap Open to start the app BOOM. You're done. Remove 1mobile notifications You may notice that the 1mobile Market now throws some unwanted notifications into your Hub however. To remove this takes a bit of extra work, but it's well worth it. Find out how to remove them by following this thread in the forums. Now also keep in mind that not all apps you'll download will actually run on BlackBerry 10. That being said, we've had plenty of luck with most apps we've tried from the 1mobile Market. Hit up the comments and let us know if you come across any that aren't working. If you have any other tips on using the 1mobile Market be sure to let us know!
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim |
11-03-2020, 15:47 | #2 (permalink) |
Banned Join Date: Oct 2020 Location: Santa Ana, CA Age: 36
Member: 2971281 Status: Offline Thanks Meter: 2 | This was really helpful and easy to follow. Thank you. emergency roof tarp bradenton |
