htc valente wx hi supporter how to root and s-off and unlock? |
Install Custom recovery. Connect recovery mode. The use of options. |
1.17.0000 2.06.970.4 there're no recovery Index Of : Main Directory / ROM_Android_WindowsMobile / ROM_Android / HTC / Valente where from download? |
cant unlock bootloader i followed this guide How to SIM-Unlock for HTC J, ISW13HT | hello.c d:\srockyou\tools>adb shell adb server is out of date. killing... * daemon started successfully * root@android:/ # dd if=/dev/block/mmcblk0p4 of=/sdcard/mmcblk0p4 dd if=/dev/block/mmcblk0p4 of=/sdcard/mmcblk0p4 2+0 records in 2+0 records out 1024 bytes transferred in 0.007 secs (146285 bytes/sec) root@android:/ # exit exit d:\srockyou\tools>adb pull /sdcard/mmcblk0p4 mmcblk0p4ORIG 0 KB/s (1024 bytes in 5.576s) d:\srockyou\tools>adb push mmcblk0p4MOD /sdcard/mmcblk0p4MOD 200 KB/s (1024 bytes in 0.005s) d:\srockyou\tools>adb shell root@android:/ # dd if=/sdcard/mmcblk0p4MOD of=/dev/block/mmcblk0p4 dd if=/sdcard/mmcblk0p4MOD of=/dev/block/mmcblk0p4 2+0 records in 2+0 records out 1024 bytes transferred in 0.001 secs (1024000 bytes/sec) root@android:/ # sync sync root@android:/ # reboot bootloader reboot bootloader d:\srockyou\tools>fastboot getvar cid cid: KDDI_801 |
edit mmcblk0p4ORIG using HexEditor You will see “KDDI_801″. Please rewritten with “111111″. After that, save it. Please name the file to “mmcblk0p4MOD”. Then, write the file to your phone. 1 adb push mmcblk0p4MOD /sdcard/mmcblk0p4MOD 2 adb shell 3 # dd if=/sdcard/mmcblk0p4MOD of=/dev/block/mmcblk0p4 4 # sync 5 # reboot bootloader Your phone will reboot and go to fastboot mode. 1 fastboot getvar cid cid: 111111 finished. It will be OK if displayed in this way. After that, go to HTCDev to unlock. Goodluck... ;) |
1 Attachment(s) yes i did it but still cid still same here is modificated |
where is supporter where is prove valente wx s-off cid change etc |
just copied this 1 but still same d:\srockyou\tools>adb push mmcblk0p4MOD /sdcard/mmcblk0p4MOD * daemon not running. starting it now on port 5037 * * daemon started successfully * 166 KB/s (1022 bytes in 0.006s) d:\srockyou\tools>adb shell root@android:/ # dd if=/sdcard/mmcblk0p4MOD of=/dev/block/mmcblk0p4 dd if=/sdcard/mmcblk0p4MOD of=/dev/block/mmcblk0p4 1+1 records in 1+1 records out 1022 bytes transferred in 0.001 secs (1022000 bytes/sec) root@android:/ # sync sync root@android:/ # reboot bootloader reboot bootloader d:\srockyou\tools>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 1.17.0000 (bootloader) version-baseband: 1.53.30.0905 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2.06.970.4 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: SHTBG031171 (bootloader) imei: 35170105132**** (bootloader) product: valente_wx (bootloader) platform: HBOOT-8960 (bootloader) modelid: PK0710000 (bootloader) cidnum: KDDI_801 (bootloader) battery-status: good (bootloader) battery-voltage: 3852mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 80968db3 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.081s |
