Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > IRKEY
Old 10-29-2013, 18:02   #1 (permalink)
Member: 2051424
Thanks Meter: 16
Repair/Change IMEI on HTC One M7?
Hello,
Is it possible to change IMEI for HTC One M7? Phone is S-OFF from moonshine/etc.
Thanks.
Old 10-30-2013, 08:04   #2 (permalink)
Member: 598854
Thanks Meter: 141
yes ... 100% possible
choose m7wlj model
The Following User Says Thank You to renzox For This Useful Post:
Old 10-30-2013, 08:04   #3 (permalink)
perspolis's Avatar
Member: 60103
Sonork: 108841
Thanks Meter: 1,328
Originally Posted by BubluMian View Post
Hello,
Thanks.
Yes, if S-OFF is possible. But it must be done in recovery Custom mode.
Old 10-30-2013, 17:24   #4 (permalink)
Member: 2051424
Thanks Meter: 16
Phone is already S-OFF.
You mean IMEI Repair/Change on Htc ONE M7 is possible only using custom recovery like TWRP or CWM?
Old 10-31-2013, 06:53   #5 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
If phone already s-off there is two method to repair imei..
1)fastboot,goto useful tool and then goto hack tab and there you will see imei repair option..
2)CWM,below hack tool there is cwm option you can try that too...
Old 10-31-2013, 08:55   #6 (permalink)
gulka's Avatar
Member: 276322
Thanks Meter: 293
Do not get S-OFF, do not clean the inscription tampered.program reports success, but in fact not correct. Need Your Help
Old 10-31-2013, 09:14   #7 (permalink)
gulka's Avatar
Member: 276322
Thanks Meter: 293
Old 11-13-2013, 11:50   #8 (permalink)
Member: 2003887
Thanks Meter: 6
I have a htc one m7 with hboot 1.54, OpenRecovery-TWRP-2.6.3.3-m7.img and s-off status via Rumrunner, do you think I can change imei to my htc one? or you need other information to tell me if I can do it?i can do it only using ir-key? if is it possible only via ir-key can you say me step by step how can do.
Old 11-13-2013, 14:01   #9 (permalink)
perspolis's Avatar
Member: 60103
Sonork: 108841
Thanks Meter: 1,328
http://forum.gsmhosting.com/vbb/f857...10/index2.html
Old 12-23-2013, 06:52   #10 (permalink)
Member: 2090326
Do I need to buy special hardware for this? If so, where I can buy one?
Btw, i'm from US.
Thanks
Old 06-21-2014, 08:29   #11 (permalink)
Member: 1988296
Sonork: 100.1656132
just s-off and unlock bootloader , then type in cmd " fastboot oem writeimei imeinumber"
Old 07-06-2014, 19:29   #12 (permalink)
Member: 1853831
Sonork: 0912879928
Thanks Meter: 2
Continue excellent youth
Old 08-08-2014, 12:53   #13 (permalink)
Albelektronik's Avatar
Member: 178513
Thanks Meter: 109
Htc one m7 htc m7_ul imei problem
Hello friends,
i have HTC One M7_UL
Boot Unlocked, Super CID, Root, S-OFF
i have try many times to change the IMEI, if i do it from fast boot ( HBOOT) ok, i can change it and i can read the new IMEI too, after i reboot in normal mode i can see the same OLD IMEI, so the change don't come... strange, i have try from command line too.
Here are phone details. What is wrong?
Model: m7_ul
SN: FA382W904481
Biuld Ver.: 4.4.2
Base Band: 4T.27.3218.14
FCC ID: PN0710000
Build number: 5.11.401.10
Boot loader: 1.57.0000
CID: 11111111
Build ID: 0.5 KOT49H
Product name: htc_europe
Product Code: htc
IMEI in HBOOT: 111111111111111
IMEI in normal mode: *******53493742
Strange....
Old 08-10-2014, 15:53   #14 (permalink)
Member: 1988296
Sonork: 100.1656132
Originally Posted by Albelektronik View Post
Hello friends,
Model: m7_ul
SN: FA382W904481
Biuld Ver.: 4.4.2
FCC ID: PN0710000
CID: 11111111
Product Code: htc
Strange....
write in cmd "fastboot oem writeimei imeinumber "
Old 08-10-2014, 16:06   #15 (permalink)
Member: 178513
Thanks Meter: 109
Hello, thnx for the suggestion, I have specified below that I have try ... Not work.
Inviato dal mio HTC One utilizzando Tapatalk
The Following User Says Thank You to Albelektronik For This Useful Post:
Page generated in 0.24992 seconds with 9 queries
