Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 04-17-2014, 16:09   #1 (permalink)
cellcare sams's Avatar
Member: 1537063
Thanks Meter: 74
mtk android not connct
videocon a24 pattern lock . i am tried not sucessful.what reason plz help
Old 04-17-2014, 16:14   #2 (permalink)
Member: 1537063
Thanks Meter: 74
Old 04-19-2014, 05:43   #3 (permalink)
zubair pathan1's Avatar
Member: 1867883
Sonork: 100.1654594
Thanks Meter: 27
Originally Posted by cellcare sams View Post
first you need to enable usb debbing
Old 04-19-2014, 15:02   #4 (permalink)
Member: 1645482
How to enable usb debbugging when the phone has pattern lock, screen lock or user lock?
Old 05-26-2014, 05:48   #5 (permalink)
Member: 407669
Thanks Meter: 82
How to enable usb debbugging when the phone has pattern lock, screen lock or user lock?telme sirrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Old 05-26-2014, 05:58   #6 (permalink)
sunilkumar70791's Avatar
Member: 1432329
Sonork: 100.1615863
Thanks Meter: 1,626
not possible open usb dabangg
finaly soulition read flash and format
problem solve
Old 05-26-2014, 06:00   #7 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
bro ur debbng is already open just driver problem install corect driver and try agian by andoraid tool,,,or try by hand mothed press vell down and power
Old 05-26-2014, 06:11   #8 (permalink)
Moderator
gsm mithun roy's Avatar
Member: 1537689
Sonork: 100.1669550
Thanks Meter: 2,219
trun on your locked phone connect to pc install usb driver and adb interface driver if usb debug on then asking for adb driver install and then try if debug opting off then you have to flash your phone
Old 05-26-2014, 07:10   #9 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 4,307
@ cellcare sams ...
That Mean Your Phone's USB Debug Is Off ...
At The Moment There are many Way to Remove pattern lock In MTK Phone ..
You Can Try Those Way ..
Follow Those Step ......
Step 1 ...
  • Go to MTK TAB
  • Do Enable imei
  • Click on Android tool
  • Click on Run
  • Click on MTK 65xx New Method
  • Fill imei in boxes
  • Click on Write imei
  • When software saying searching for port
  • Insert USB cable to phone in powered OFF condition !!
  • Waiting software for process complete
  • See device manager adb (Android Debug Bridge)appear
Connect your pattern locked phone for wipe data or reset gmail
Remove pattern lock with Volcano or any adb tool ..
Step 2 ....
  • Open Latest Volcano ...
  • Go To Android Tool ...
  • Select MTK Cpu Type ...
  • Get Read Info ...
  • Get Backup Flash ..
  • If You Get Format Address ...
  • Then Do Manual Format ...
Try Any Of Those Your Problem Will Solve ...
Post Result ..
Br,
AniAXN
Page generated in 0.17129 seconds with 9 queries
