04-23-2017, 10:51 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Portugal.Chelas Age: 39
Member: 12966 Status: Offline Thanks Meter: 133 | A500FU Imei 0 repair |
04-23-2017, 13:57 | #2 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,804 | pal do this efs backup envm then do clear nvm phone will restart then go gen setting |
The Following User Says Thank You to profkefah For This Useful Post: |
04-23-2017, 14:44 | #3 (permalink) |
Member: 12966 Status: Offline Thanks Meter: 133 | The same ask for reset msl Code: List of devices attached d565b296 device Superuser Permissions Granted (SU) Transfered: 5128 KB/s (14680064 bytes in 2.795s) Saved as: SM-A500FU_SM-A500FU_d565b296_EFS_R58GB0S1H9Y [2017_04_23_14_39_11].bin Transfered: 4557 KB/s (3145728 bytes in 0.674s) Saved as: SM-A500FU_SM-A500FU_d565b296_NV1_R58GB0S1H9Y [2017_04_23_14_39_11].bin Transfered: 5027 KB/s (3145728 bytes in 0.611s) Saved as: SM-A500FU_SM-A500FU_d565b296_NV2_R58GB0S1H9Y [2017_04_23_14_39_11].bin Transfered: 5180 KB/s (3145728 bytes in 0.593s) Saved as: SM-A500FU_SM-A500FU_d565b296_NV3_R58GB0S1H9Y [2017_04_23_14_39_11].bin Path: C:\Program Files (x86)\SarasSoft\UFS\UFS_SAMs\SM-A500FU\EFS\ Done in: 00:31.020 None of Diags Ports Selected Samsung SM-A500FU (A5 LTE) at USB (COM33) [DIAGS] {Read ENVM} OFFLMODE: OK Set SPC Password: 000000, OK MDMVERSN: Nov 4 201515:21:04Jun 05 201504:00:00EAAAANVZ MDMBUILD: MPSS.DPM.2.0.c5-00075-M8936FAAAANUZM-1.21700.1 NV IMEI1: 000000-00-000000-0 Get Names GN PROTECTED_NODE: /.efs_private Get Names GN PROTECTED_NODE: /nvm Get Names GN PROTECTED_NODE: /safe EFS2 Read Found: 624 File(s), 0 Link(s) EFS2 Read Done : 624 File(s), Time: 00:12.679 NVM_SIM_1 Read Done: Start 0, 1 Active Item(s), Time: 00:21.652 NVM Read Done: Start 0, 655 Active Item(s), Time: 00:22.195 Saved as: SM-A500FU_000000-00-000000-0_07 [2017_04_23_14_40_55].envm Path: C:\Program Files (x86)\SarasSoft\UFS\UFS_SAMs\SM-A500FU\NVM\ OFFLMODE: OK Samsung SM-A500FU (A5 LTE) at USB [ADB] {Clear NVM} List of devices attached d565b296 device Superuser Permissions Granted (SU) Clear NVM Done in: 00:00.715 Wait, Restarting ADB Reboot Done Samsung SM-A500FU (A5 LTE) at USB (COM32) [MODEM] {Gen.Settings} MODEMCON: OK Certification Failed (KEY ID) Use [Reset MSL] to Bypass MSL Security |
04-23-2017, 17:40 | #5 (permalink) |
Member: 12966 Status: Offline Thanks Meter: 133 | Yes with rj45 able to write cert but no network i find a backup of envm write all ok imei and network. So it's better always use rj45 cable? |
