02-27-2018, 18:08 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Western Cape, South Africa
Member: 10168 Status: Offline Thanks Meter: 153 | Corrupt Registry after running Panel 2708 - Solution If you are used to using RegEdit.exe then it's a simple fix: Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\SarasSoft\UFS3\GlobalO ptions in RegEdit and look for the corrupt entry something like: IMEE=C3ACB79742086A6E534786FDF49E4A085BB5FE45 If you have a 64 bit machine Navigate to: HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\SarasSoft\ UFS3\GlobalOptions in RegEdit and look for the corrupt entry something like: IMEE=C3ACB79742086A6E534786FDF49E4A085BB5FE45 Right click on IMEE and Rename to IMEI Right click again and chose Modify and for Value Data enter TRUE Should you not find the entry for some reason, use RegEdit search function to find IMEE whatever you do, don't just play with the registry!! Note: Every time that you use Panel 2708 you will need to repeat this task!! |
The Following 17 Users Say Thank You to jim.mahoney For This Useful Post: |
